Thread: hids fitted, too bright?
    newport
    Default hids fitted, too bright?
    anyone come across this? hids fitted to prefacelift, much better imo, but being flashed by oncoming cars, alligned correctly, can they just be too bright?
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Try dipping them down, got 8000k's in mine and never been flashed
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Alignment might be out. I pressume you've made sure they're in the holders correctly? Try your nearest MOT station and get them to check the headlight alignment Then you'll know for sure. I had 4300k 35 watt ones in mine and with them correctly aligned, I left them on position 0 and never got flashed once in about 4 months.
    Engine : Z20NET
    cont is probably right, your alignment should be correct first before you consider using the dip switch, mine is also on 0
    Regular Member Das's Avatar
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    35 or 50watt? Ive had my HIDs in for about a year now and never been flashed.
    newport
    35w 4.3k, they were set to 0, now adjusted to 4, and its dropped approx an 1" and a half on the back end of a car that is parked approx 4' in front of ours, so should be alot better, but will get it properly alligned at garage just to be sure, would have thought 0 should be the position it should be at normal?
    Here
    33 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Yea I run with mine on 0 unless I have 3 people in the car.
    Regular Member MURDO's Avatar
    Co.Clare, Ireland
    yup, have 8000k in mine. Have them set up so normal level is at 2. and if i have heavy gear in the car i just drop it down a notch or so.
    Regular Member RobertHayman's Avatar
    Sidmouth
    Vehicle : Insignia
    Engine : 2.0 CDTI auto
    Year : 63
    Mileage : 8,500
    On my face lift, I turn down 1 notch for normal use, then don't get flashed.
    If I am in constant traffic I turn them down 2 notches, courtesy.
    If you are in a line of traffic, you don't need to see far ahead.
    Sodding Typical on Sea
    I have my dipped beam set to the correct height, and passed and MOT, but I tend to find that I run them in pos.1 in town and when behind stuff just so as not to cause undue glare, though when I was tailing a mate of mine, he said they were perfect whn I did have them fully up in pos.0
    If I were youm I'd just double check them to be safe.
  1. hids too bright
    By Silver Vectra C in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2011, 07:21
  2. hids fitted
    By TomiboyC in forum Styling
    Last Post: 11th February 2011, 13:49
  3. HIDS fitted
    By treasure22 in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2010, 20:44
  4. HIDS fitted
    By slick91 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2010, 08:26
  5. hids fitted
    By simon1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2009, 22:02
