Thread: Symbol on the Dash
    Regular Member D-S-Dave's Avatar
    Jun 2006
    Home init
    Default Symbol on the Dash
    Hi,
    Can someone solve my problem. Each time i turn my key in the ignition INSP appears for a short time. It appears above the mileometer count. Question is what does it mean? I've had the service symbl before (oil can and spanner) but not this one. Help cheers.
    Regular Member Perry's Avatar
    Watford Herts
    Found this in the manual,
    Vehicles with a fixed oil change and service interval, InSP appears in the trip odometer when the ignition is switched on.
    Have the service work required carried out within 1 week or 300miles after the light has appeared.
    Jun 2006
    Home init
    Had it serviced & mot'd over a month ago. Should'nt vauxhall of sorted it or is it a quick fix i can do?
    Regular Member IamtheStig's Avatar
    Nov 2005
    Somewhere in time
    Press the trip reset in and hold it,turn the ignition on and after about 10 secs it should reset itself.....
    Jun 2006
    Home init
    Thanks I'll try that in the morning.
    press the button in, press the brake pedal down, then turn thr ignition to posn 2.. hold everything down till the display changes,,then the service light is reset..
    Feb 2006
    Guttedsville
    Don't forget to pat your head and rub your tummy at the same time though.
    Nicking Ya Dinner.
    Dont touch it, take it back to the Vx garage and ask why after a mth the car says it needs a service, it's nothing to worry about as said above, but it makes the garage look slack to you and they will know it, and also you might get something in return, like a fresh oil change for nowt.
    Jun 2006
    Home init
    Default Your right.
    Your right Vaux Veteran cheers. Taking it back tomorrow.
    Pugster
    Regular Member simac's Avatar
    Wirral
    It's probably just got out of synch with the service intervals. Mine did the same thing when I bought it.
    The INSP is displayed at 20k miles or 12 months, I bought mine a couple of weeks before it was a year old. They serviced it when I bought it but of course the timer for the service light is still running ! so INSP was displayed a month or so after I bought it. I ignored it until the next service was due, then it was reset and it came on this year at 12 months since the last service.
    It's just had an early service before light came on, was with mine anyway
  1. Symbol on dash????????
    By dannyjpuk in forum Vectra C / Signum Troubleshooting
    Last Post: 13th December 2011, 15:48
  2. Symbol lit on dash
    By MARKPRIOR in forum Diesel Engine related
    Last Post: 2nd February 2011, 14:31
  3. dash symbol
    By Dwabo in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2010, 13:29
  4. dash symbol?
    By twaiter in forum Suspension, Wheels & Brakes
    Last Post: 16th March 2010, 23:55
  5. Symbol on Dash
    By thegoldenbullet in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2007, 09:42
