Results 1 to 3 of 3
Thread: Poor starting 1.9 CDTI 120 Hot & Cold
    Sep 2011
    Gt Yarmouth
    Question Poor starting 1.9 CDTI 120 Hot & Cold
    Can anyone help with my poor starting 1.9 cdti 120 Vectra (2007) hot & cold. I have had the car from new and it has only covered 27k and is well maintained. The problem started while under warranty when it would occasionally be a problem to start when hot. As no fault codes were recorded and it did not do it for the dealer it never got resolved. It has progressively got worse and now does it hot and cold. It seems to try and start on 2 or 3 cylinders which ain't enough to keep it going so you have to keep the starter turning untill it fires up properly. Not good for the starter or battery. When it eventually starts you get a cloud of smoke.
    Following tips on here I have cleaned and modified the EGR valve, changed the thermostat temp sender, replaced the crankshaft sensor and was going the modifie injector 3 but mine appears to have the heavier gauge wire and clean tight connections.
    Any other advise will be much appreciated.
    Wales
    valve clearances? (yes, the 120 has them...)
    Injector leak off test?
    Sep 2011
    Gt Yarmouth
    Thanks for the pointers,
    I have checked the valve clearances and they are ok.
    Am I right in saying the injector leak off test needs to done by a specialist ?
    Any idea of cost ?
  1. Poor starting.................but not from cold
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2013, 07:32
  2. Poor Starting CDTI 150 Auto
    By 1075 in forum Engine & Drivetrain
    Last Post: 26th January 2013, 18:06
  3. 56 plate cdti 120 cold and poor starting
    By bigbadcat in forum Engine & Drivetrain
    Last Post: 5th June 2012, 17:28
  4. poor cold starting CDTi 120
    By bembo449 in forum Engine & Drivetrain
    Last Post: 21st May 2011, 16:53
  5. 03 vectra dti poor starting when cold
    By jono m in forum Engine & Drivetrain
    Last Post: 11th November 2010, 14:16
signum 1.9 cdti bad for starting
1.9 12 cdti bad starting
