Thread: Blown Baffles
    spoons
    Guest
    Default Blown Baffles
    How do you know if the baffles in the back boxes are broken?
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    well in my old escort when they went ,I had 20 foot of trailing what looked like horse hair behind the car ..
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    I saw that on a Peugeot the other day
    WGAF#5
    dependant on the type of baffles fitted ... if there the fixed "solid" type get under the car and use the side of your fist and hit the back boxes(obviously make sure its not hot first ) if there is a rattle then there breaking up inside
    the other type as stated will have steel wool or equivalent and then it starts falling out the back
    hth
    spoons
    Guest
    Thanks guys, nope... not what I'm thinking then.
    Just developed a metal rattle at the back of the car and I think its the exhaust backboxes.
    Might just be rattling against the bodywork so going to check when I get it back home
    May 2011
    bispham, blackpool
    Quote Originally Posted by spoons View Post
    might be heatsheld between backbox and body
    if not its possable the baffle has dropped inside get under the car and hit each back box you might be able to hear one of them rattle. in the 2mth i owned a renault scenic i had a baffle go in the center had it replaced the first week of having the bus then had to get it replaced again before i got rid as it went again within 2 mth thats french cars for you it only rattled on tickover but the sound was horrid
  1. Blown again.....!
    By Chuddy in forum Electrical & ICE (including SatNav)
    Last Post: 12th December 2011, 00:59
  2. hid bulb blown
    By n8sby in forum Styling
    Last Post: 12th March 2011, 21:39
  3. keep getting blown away
    By andy76 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2011, 10:06
  4. Vectra blown up by IED!
    By Big Knox in forum General Chat
    Last Post: 21st December 2010, 12:45
  5. Think my amp has blown
    By danny1992 in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 13:48
back box baffles blown
