Thread: 2.0L DTI Power loss
    Oct 2011
    Barnsley
    Default 2.0L DTI Power loss
    Hi all, this is my first post.
    I have had the car (2004 2L DTI) for 7 months now covered 7000 miles now 84,000 on clock..all been fine up to a few weeks back, when the spanner light came on and went into safe mode. Took to local garage he replaced the thick pipe (split) that goes to the turbo. He also told me that error code p0100 Mass or volume air flow sensor may need replacing. When driving at low revs everything seems fine, when I give it more revs the engine revs fine, but the power takes ages to catch up (does this more when engine is up to temp) (loss of power)
    I have changed the Mass air sensor and still the same problem, not getting any warning lights coming on ?
    Hope someone can help before insanity kicks in.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Morning tez
    check all your vacuum hose connection,s for splits or signs of perishing.also check all your other intercooler pipes for sign,s of splits , get a friend to rev the engine for you and listen for the sound of air escaping or signs of oil escapeing from the pipes
    Failing that give your boost sensor a clean with some carburettor cleaner
    and still loving it
    Oct 2011
    Barnsley
    Quote Originally Posted by bobssignum View Post
    Morning tez
    Thanks Bob,
    I have been checking the pipes this morning.........seem OK.....I will give the boost sensor a clean as soon as I find where it is :-)
    Engine : 2.0DTi
    Mileage : 73350
    Boost sensor is the right hand one of the two on the inlet manifold , the one closest to the hose
    and still loving it
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Jus out of inteas what colours ya car I sold my old dti 7 months ago or so up near where u are
    Oct 2011
    Barnsley
    Quote Originally Posted by paulvectrac View Post
    Black, purchased from a garage in Doncaster with full service history, owned by someone local before me.
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    No not my old one mine was same year and same milage lol plus I sold it up near u
    Oct 2011
    Barnsley
    UPDATE Took the boost sensor off and cleaned with carburettor cleaner, while I was at it took the EGR valve off too and cleaned it.
    Just took it for a spin ....... revved round to 4,500 but still lacking power....when driving at higher revs it drives as though the clutch is slipping (not under normal driving) but I don't think it's the clutch.
    I am lost......not in the car by the way.....lost on what to do next.
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. loss of power
    By STRETCH2009. in forum Engine & Drivetrain
    Last Post: 8th August 2012, 18:44
  3. Power loss HELP
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 28th July 2012, 12:34
  4. 2L DTI '53 Loss of Power
    By BigTunz in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 17:27
  5. loss of power
    By philly in forum Engine & Drivetrain
    Last Post: 11th May 2009, 07:21
vectra c 2004 dti lossof power
p0100 vectra 2.0l dti
