Thread: Rear Interior Lights - Ribbon Cable Ripped
    Sep 2011
    Paisley
    Unhappy Rear Interior Lights - Ribbon Cable Ripped
    Hi,
    I went to replace the bulbs in the rear interior light of my 2.0DTI Elite today as the light wasnt working - only to discover that the ribbon cable going to it had been ripped.
    Whats the best way to fix this?
    Is it replacing the cable, soldering the cable back together(difficult) or can I try a DIY job like electrical tape etc?
    I also have the "check safeguard" message - would this be causing that error at all?
    Feb 2011
    Selby
    It is possible to solder wires to the ribbon, you've just got to be careful about applying just enough heat to melt solder, but not melt the plastic too much. Clean up the copper strips with glasspaper so they're bright and shiny, tin the ends of the wire you're using as a repair with plenty of solder, thensolder it to the ribbon with a low wattage (15W) iron or ideally a temperature controlled one.
    Alternatively, you can mechanically join the ribbon conductor by carefully separating it from the plastic backing, rolling it into a tube and pushing it into a screw terminal block. Repeat for the other conductors in the ribbon. If you're lucky, the other side of the ribbon will reach to the same terminal block. If not, just put wires between two blocks.
    If there's room, I prefer the second option.
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    i have used staples on mine with tape over the top works ok
    Sep 2011
    Paisley
    Quote Originally Posted by cossiejay View Post
    I like the sound of this option lol nice and easy.
    How likely is it to break though?
    Feb 2011
    Selby
    That should work as long as you make sure that the two parts can't move relative to each other which might over time cause it to tear. Maybe araldite or some other hard setting glue. And make sure the pointy ends of the staples stab into the copper for a good connection.
    Edinburgh
    yes that will probably be causing your safe guard warning. its definitely worth trying to fix if you can, its about £50 for a new one from the dealer!!! :O
    Regular Member baz2003uk's Avatar
    Mar 2007
    swindon
    Quote Originally Posted by rich r View Post
    sorry to bump an old post
    have the same issue with mine but the black connector has come off and there is no bearing copper at the ends of the ribbon
    you say about rolling the plastic backing off which sounds do able as if i did this it would bear a bit of copper to make the connection work on the black connector
    is there an easy way to separate the plastic backing and what side do i try to roll back
    Feb 2011
    Selby
    No easy way I'm afraid - just be gentle with whatever tools you have to hand. You might find some solvents soften the plastic making it easier to strip off, or you might find it's easier to use a thin knife to separate the plastic.
    You're aiming to have the copper strips on their own, so you can either roll them (to make a short 'wire') or solder to them without melting the plastic.
  1. For Sale: Autodimming Mirror and Ribbon Cable
    By Aidi in forum Parts for sale
    Last Post: 27th January 2013, 21:21
  2. rear interior light ribbon
    By baz2003uk in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2012, 20:23
  3. I need your help please with Ribbon Cable-Auto Wipers.
    By Vaux-Man-G in forum Electrical & ICE (including SatNav)
    Last Post: 18th September 2011, 17:29
  4. Auto Dimming Interior Mirror and Roof Ribbon Cable
    By LeeU in forum Parts for sale
    Last Post: 18th December 2010, 16:25
  5. Rear Interior Light/no Ribbon
    By BRUCE120 in forum Styling
    Last Post: 10th December 2006, 16:38
vauxhall ribbon wire
vectra c rear ribbon cable
vauxhall signum rear interior light ribbon cable
how to repair ribbon wiring in vauxhall
vectra c rear interior light ribbon
vectra c interior light ribbon cable
vectra c rear interior light not working
where can repair safeguard warning ight on vauxhall vectra c
