Results 1 to 10 of 11
Thread: possible flywheel problem???
    Sep 2011
    kent
    Default possible flywheel problem???
    Hey peeeps!
    Right... as per my other thread, i done the drivers front hub/wheel bearing today an it got rid of a few horrible noises an so on but.................
    I still getting a vibrating/judder???? when pulling away, Not terrible but still not smooth, its ok when cruising/following traffic just mainly when you accelerate?
    Also noticed today that you can kind of feel it when you rev it on tick over?
    Flywheel or something else?
    TIA
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    With the engine running, and car parked in neutral, press the clutch slowly. You'll hear it start to rattle badly when it's about half way down if it's your DMF.
    Quote Originally Posted by Alansvecky;[B
    1641901Also noticed today that you can kind of feel it when you rev it on tick over?[/B]
    Does sound a bit like my missus' car when her flywheel went....
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If it's the flywheel I wouldn't worry mine has been rattling for the last 107k. So when funds allow get it fixed but I wouldn't say it's an urgency.
    Sep 2011
    kent
    ah right ok guys cheers... and Tony, pressing the clutch down while in neutral makes no noise difference at all?
    its so hard to describe, it may just be me as my last car was kinda noisey not used to having a quiet engined car pmsl
    Sep 2011
    kent
    Right.. just noticed that on a hill start (fairly steep) the juddering/vibration is a lot worse than it is when pulling away on a flat road??
    Does that point to anything else?? or point more towards the flywheel? also is mine defo the DMF?? 02 vectra c 2.2ls thanks
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by Alansvecky View Post
    That def sounds like a clutch or DMF related issue tbh. What's the mileage and has the clutch been changed before?
    HTH
    Sep 2011
    kent
    its on 107k, got part s/h but no mention of clutch? are you able to top up or check the hydraulic clutch fluid level? if that was low would it cause that kind of problem?
    Sep 2011
    kent
    Ok..... so..... took it to a garage this morning, guy drove it round for a few miles, said in his opinion its very early signs that theres slight play in the dmf.... quoted £600-£700 including parts.. an arguable price or pretty fair??
    I am kind of tempted to do it myself ..... hmmmmm .....
    exeter
    thats not a bad price for dmf and clutch
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Is that price for just the DMF? Or the clutch, dmf, and slave cylinder?
    Best get all three done while the 'box is out
  1. dmf to smf flywheel
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 25th November 2012, 22:34
  2. 3.2 flywheel
    By bembo449 in forum Vectra C / Signum Car Chat
    Last Post: 21st June 2011, 23:05
  3. Flywheel problem ???
    By big nath in forum Engine & Drivetrain
    Last Post: 17th June 2009, 19:28
  4. Flywheel ?
    By 900ss in forum General Chat
    Last Post: 31st October 2008, 22:46
  5. flywheel and dmf
    By willoftoon in forum Engine & Drivetrain
    Last Post: 24th August 2008, 10:45
