Results 1 to 10 of 14
Thread: advice on tyre wear
    Default advice on tyre wear
    right here goes
    went to a wedding yesterday and as i drove away from the photos being taken i had a blow out in the car on the off side
    managed to change the wheel to the space saver ( not easy in a morning suit trying not to get it dirty )
    removed the wheel and had a look at it and was extremely shocked at what i saw
    the damage goes all teh way round the whole inside of the tyre
    i also checked the near side and it was almost identical
    so i had 2 new tyres fitted this morning and had the tracking checked as that was i thought had caused it ( too much toe out )
    but they said the tracking was spot on
    any ideas gents ?????
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Isnt this a common problem on the Vec C?....something to do with some suspension bush etc?
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Is the car modified in anyway with the suspension etc? and were they fronts? also a simple tracking check isn't sufficient to see this kind of issue you need a 4 wheel alignment which will check such things as front and rear camber as well
    paul , the suspension is all standard , just been looking into hunters 4 wheel alignment so will get it all checked
    just mystified that it happened on both front tyres at the same time
    oh yeah and as i was changing the wheel and lowering it back onto the floor the damn crappy vauxhall jack split in 2 !!!
    24 Post(s)
    Vehicle : M5
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    My rear camber was out and the rear toe in which made the inside edges of the nearside front wear prematurely, just shows a 4 wheel alignment found it. Its not something they do from new so the fault can just sit there until you discover it lots of other folks with similar set up issues.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    What make are the tyres? All I can make out is DSST and run flat.
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    My v6 tyre had cracked all they way round when I was checking them and probably wasn't far off from ending up like yours
    Just an idea but have you removed the under tray? Just thinkingnthe inner edges off my front gyres get really warm from the engine maybe the heat has worn rubber prematurely?
    WGAF#5
    Quote Originally Posted by Grumpy1954 View Post
    There dunlops
    That damage looks more like permanent underinflation, possibly from a puncture
    The tyres may look inflated but unless you physically check the pressures the tyre may in fact be underinflated
    This is a common problem when RFT tyres are fitted to cars without pressure monitoring equipment
    If the tyre remains underinflated then it will eventually fail catastrophically, typically within 150 miles
    However, very unlikely if both front tyres suffered the same issue on both inside edges
    Nextly what tyre pressures were you using? (On the 3.0 V6 CDTI and equivalent it is quite critical)
    I've had my front tyres down to 28PSI and can feel they are underinflated
    Below 22PSI they begin to overheat
    Finally, what size and specification are they?
    hi m8internet
    the tyres were dunlop sp 01 size was 225 45 17
    now i need to check what the proper size for the tyres should be
    the handbook says they should be
    215/50/r17
    or
    225/45/r17
    the new tyres fitted yesterday were
    215/45/17 87w
    im not sure these are correct
    also i was running the older ones at 34psi but checked autodata yesterday at the tyre place and they should be 39 psi
    can anyone shed some light on whether the new tyres are ok or do i need to take them back and change them for different ones
  1. Need advice on tyre wear please.
    By John Bishop in forum Suspension, Wheels & Brakes
    Last Post: 27th September 2012, 13:16
  2. Tyre wear advice needed
    By ryantcb in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2011, 20:55
  3. tyre wear
    By dreams3577 in forum Vectra C / Signum Car Chat
    Last Post: 3rd November 2010, 20:08
  4. outside tyre wear
    By whatthevecisup in forum Suspension, Wheels & Brakes
    Last Post: 7th April 2008, 21:17
  5. Uneven tyre wear and my local fitters technical advice...
    By Deadman in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2007, 23:24
