Thread: fitting rear electric window questions, tech2
    newport
    Default fitting rear electric window questions, tech2
    checked today to see if i have the 2 pins at b pillar cable for fitting rear electric windows, and i have, so it looks like this is going to happen, but i have a few questions first.
    how much do you think it will cost for tech2 to activate them when fitted? does it have to be vauxhall or can local garages do it?
    will the front windows still work via the new switch before its all activated or do i keep the original switch unit in until im ready
    on the new switch unit there is a button in between the wing mirror buttons which my original switch doesnt have, what does this do, and i assume it wont work when the switch is activated?
    do i need to put a fuse in anywhere to get power to the rear for fitting?
    and last question lol, if when i sell the car, could i strip out the electrics and put it back to original winders, would that need tech2 to get the old switch to work again?
    cheers in advance
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    1: about 40-50£
    2: will work no problem
    3: its for disable the rear switches so they cant open windows
    4: yes check how2
    5: nothing just remove them.
    newport
    ahh, with you now, so that button is just an indicator, which you use the slide switch under it to lock the rears?
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    yep, just a press, and when coded, it will light up red, to show that they are disabled.
    No the slide switch is for what windows you want to control from the drivers seat.
    newport
    oh yea, didn't even notice there was only 2 window buttons
    that makes sense now lol cheers
  1. Electric window questions...
    By Chunklamb in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2012, 17:50
  2. fitting electric rear windows and tech2
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 17th August 2011, 04:12
  3. Rear electric window
    By slipperysam1984 in forum Bodywork & Interior
    Last Post: 21st July 2011, 15:58
  4. Rear Electric window
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 29th April 2008, 02:23
  5. Rear electric windows pre tech2 ?
    By lofty in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2008, 23:25
