Results 1 to 10 of 11
Thread: Inlet manifold 1.9 cdti 150 part numbers?
    Regular Member Mads's Avatar
    Ipswich,.UK
    Default Inlet manifold 1.9 cdti 150 part numbers?
    hi there
    are these the current part numbers that i need to replace my inlet manifold for the z19dth engine?
    93186274 - 1 x connecting bar
    93185801 - 1 x control valve (believe this is the actuator)
    93179061 - 1 x gasket
    55210201 - 1 x Intake Manifold
    I believe that that manifold number is the newer type and I cant find the control valve/actuator any ideas?
    thanks
    Ipswich,.UK
    I want to make sure that i get the new type inlet manifold, do you think these are the same? they are the same part numbers but LMF state its the newer type
    http://www.ebay.co.uk/itm/2006447510...ht_1360wt_1037 £177.10
    http://www.lmfvauxhall.co.uk/Inducti...-Zafira-B.html £193.78
    Ipswich,.UK
    Bump
    Ipswich,.UK
    evening bump, if no replies i will go with the dearer LMF one as it says its the newer one
    The part number is correct, but you don't need the connecting bar or the actuator mate unless yours is definitely broken...
    Ipswich,.UK
    i got a new autuator off ebay for £99 delivered as some people said its like changing the cambelt and not doing the water pump. got manifold and gaskets off Lmf should be here thurs. went to local gargae to fit they quoted 8 hours £385 inc VAT, vauxhall wanted 4.5 hours £410 inc VAT so for the little bit extra ive booked it into vauxhall on monday but i have told them not to update ecu as they will wipe my remap off.
    It's nothing like that at all mate. For starters the actuator either works or it doesn't, and if it stops working it won't destroy the engine. Also, you can change it without removing the inlet manifold in the first place. I know it's not everyone's cup of tea, but I really do hate seeing people throw money away when it really isn't that difficult of a job...
    http://www.youtube.com/watch?v=G7kMp87_Xjo
    Ipswich,.UK
    Thanks mate should of pm'd you as i was getting no response i brought them. Ive done cambelt and that myself but i thought this maybe too bigger job so booked it in for monday with vx. hopefully i can sell my old actuator on and get something back?
    Haven't been on since Friday so only just read the thread. If you could do your cambelt you could easily to the inlet manifold mate - you have to take off half the same stuff anyway, hence why I did them at the same time...
    Ipswich,.UK
    That video is amazing mate, well done! just to be safe though i think i will let vx do this one mate
  1. cdti inlet manifold
    By shinyb1 in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2012, 14:47
  2. inlet manifold part numbers & prices...
    By PAULMAC77 in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2009, 23:01
  3. Inlet Manifold CDTi 150
    By Dal150 in forum Diesel Engine related
    Last Post: 25th April 2008, 09:25
