Thread: Climate control and GID
    Regular Member Ben_'s Avatar
    Audiville, WM
    Default Climate control and GID
    Couple of questions peeps
    How easy is it to fit climate control, once youve got the control panel do you need to tech 2 it....or is it just a complete faff and not worth it.
    Fitting a GID without code (still paired) again is this a tech 2 job, can i install without the stalk for limited functions?
    Or is it all a lost cause!!
    Thanks in advance peeps
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    with climate control.. well complely different from the other 2 options.. so complet new motor, and blower assembly..
    A gid for your model year, is not paird to anything.. unless its a satnav you have in your car..
    No you cant install it with out the stalk, as you wouldnt be abel to control is.. (again if you have satnav, its done via controls on radio and steerign wheel)
    Audiville, WM
    Cheers Ken,
    CC is a no then, but thought I'd ask anway.
    The GID is out of a half can GSI. I've currently only got a TID. So if i find a stalk it'd be a goer then?
    Cheers mate.
    Engine : 2.2 Direct
    Quote Originally Posted by Ben_ View Post
    Cheers Ken,
    Cheers mate.
    yes but you will also need a 32 pin plug.. (think one was for sale in the forsale section)
    Regular Member opel_estate's Avatar
    May 2008
    Sweden
    Vehicle : Opel Vectra C Estate
    Trim : Enjoy
    Engine : Z22YH
    Mileage : 35000
    by the way, you must have GID screen (or better) for the Climate control
  1. another climate control
    By Даниил in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 19:43
  2. climate control
    Last Post: 10th August 2011, 09:34
  3. climate control
    By stu_c in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 18:27
  4. Climate control Help
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2009, 00:23
  5. Climate Control
    By liphook in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 04:10
