Thread: why does it not start
    Aug 2010
    derbyshire
    Default why does it not start
    working all day on a mates vec 'c' year 2004, 1.9cdti (120). the first start of the day is nigh on impossible but after the first start it behaves fine all day.
    gave it a full service including fuel filter, new glow plugs(wow, they are a ***** to do), yet it still churns over for 2-3 mins befor finally firing up.
    anyone else had this issue and resolved it?
    no fault codes present on my op com either
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Could be a few things. Leak of pipes maybe?
    Are the glow plugs all working?
    Maybe temp sensor?
    Wirral, UK
    Vehicle : Meriva B
    Trim : SE
    Engine : 1.7CDTi
    Year : 2011
    Doing a brief search, found a few ideas.
    This might be a fuel problem where the fuel drains back into the tank or
    maybe the Leak off pipes leaking or
    the battery is not good, so the engine is not turning over fast enough to start.
    Anyway have a look here:
    http://www.vectra-c.com/forum/showth...ning+back+tank
    Aug 2010
    derbyshire
    Quote Originally Posted by TonyP2020 View Post
    funnily enough it does sounds as though it is lazy when turning over, but gets faster as you keep turning the key, almost as if the battery is building power. also the glowplug light on the dash only shows for 1 second on the cold start then does not come back on until the next day, is this right
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    You could try to disconnect the thermostat temp wire, this will keep glow plug light on & give a fast tickover, you may also get the fans on but not to worry when the wire is put back on when running everything will go back to normal, another try is to park on a decent hill nose down if things improve the leak off pipes could be changed & there may also be a bleed back to the tank, try starting after a couple of trys with the ignition on allowing the tank pump to run & stop the try to start.
    Regular Member LADmachining's Avatar
    Hampshire
    The CDTi's have an electric fuel lift pump in the tank. This primes before the engine starts and gets fuel right up to the injection pump straight away.
    For the same reason, leak off pipes are not such an issue on the CDTi engines. On the older DTi's perished leak-off pipes allowed fuel to drain back to the tank.
    Personally, I would get the compression values checked on each cylinder with the engine cold.
  1. car won't start :-(
    By michael_linford in forum Electrical & ICE (including SatNav)
    Last Post: 29th December 2012, 19:31
  2. Were do i start
    By MCCABE in forum Engine & Drivetrain
    Last Post: 6th March 2011, 21:34
  3. 2.2 sri non start
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 13th February 2011, 00:44
  4. Cars dead. Won't start. Fan runs when it would start.
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2010, 22:34
  5. 2.2 DTI will not start!!!!
    By Mark121 in forum Vectra C / Signum Troubleshooting
    Last Post: 7th September 2010, 13:02
