Thread: Replacing drivers electric window regulator
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default Replacing drivers electric window regulator
    Drivers side regulator has twisted probably beyond repair, quick look on the bay reveals a replaement will only cost around £30.
    Question is how do you remove the old one?
    Looks like it could be a ballache as there aren't many gaps in the doorskin
    Regular Member arnyjohn69's Avatar
    May 2013
    Swansea
    Vehicle : vectra c
    Trim : silver
    Engine : 1.9
    hiya,
    did you manage to fix the above as i have the same issue?
    Matt
    Engine : Z20NET
    I took it to national windscreens with the doorcard off and the guy fixed it for £20
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    Its riveted on drill the rivets out once new one is in place use bolts to put it back on unless you have a rivet gun.
    Engine : Z20NET
    I didn't replace mine, just had it fixed, which basically involved having it pulled back into shape and new rivets put in, touch wood it's been spot on ever since
    May 2013
    Swansea
    Vehicle : vectra c
    Trim : silver
    Engine : 1.9
    Fab, did they have to take the whole regulator out to straighten it? Looks like the top left rivet has come away and looks a little squiff so im gonna try and straighten it where it is and rivet it back into place and see if it holds!
    Cheers for the info so far
    Matt
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    37 Post(s)
    Engine : 1.9 DTH
    Yes they had to , there is 6 rivets to drill out and can be a pain to remove old one putting new one in , due to limited space on behind door skin, and u need rivet gun to replace ones u've drilled out
  1. Drivers Electric Window Switch
    By a18nmk in forum Bodywork & Interior
    Last Post: 16th March 2017, 23:13
  2. Broken front electric window regulator
    By alanatrr in forum Bodywork & Interior
    Last Post: 14th April 2013, 11:22
  3. Electric drivers window not right
    By big nath in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2011, 11:44
  4. 2006 Vectra C drivers door window regulator
    By Haggis in forum Bodywork & Interior
    Last Post: 9th September 2009, 22:51
  5. Drivers Electric Window Switch
    By Damian in forum Parts for sale
    Last Post: 6th June 2008, 17:05
how to put window on the mechanism on 2005 vauxhall vectra
vectra window regulator
how to replace vectra c drivers window
window fell into door vauxhall vectra.c
https:www.vectra-c.comforumshowthread.php148514-Replacing-drivers-electric-window-regulator
vectra c window regulator replacement
vectra c drivers window removal
vectra c window lifter repair
replace front driver window pel vectra
vectra c window mechanism change
changing vectra c window mec
how to remove vectra c window regulator
how to install vectra c front drivers window
remove electric window motor opel vectra
vectra c regulator rivet size
vectra window regulator repair
remove drivers side window vectra c
disassembly power window vectra c
replace drivers front window vauxhall signum
vauxhall vectra replace driver side window mechanism
how do you remove window regulator on 07 vectra
window regulator vectra
kwick fix window regulator vauxhall vectra
vauxhall vectra c window regulator settings
