Thread: white smoke wont start
    Oct 2011
    doncaster
    Default white smoke wont start
    hi i was driving home yesterday and pulled out of a juntion when the engine just packed in i managed to get to the side of the road were i tried to start the car again and a puff of white smoke came out the exhaust and the car died again has anyone any ideas on this as there are no warning lights on etc but the car refuses to start its a 1.9 120bhp vectra cdti many thanks
    dave
    Regular Member benny's Avatar
    Feb 2006
    dudley
    check the cambelt aint broken ...
    Oct 2011
    doncaster
    Default hi
    hi checked the cam belt and all is fine engine trys to start
    Full Member
    Bristol
    I would check you leek off pipes you may have a t piece broken or cracked pipe. As you said it won't start it is diesel related if air is in the system it will not start and it would have given you a puff of white smoke.
    Oct 2011
    doncaster
    Default hi sb1 uk
    now you have said that about the pipes it does make sence about 5 mile previous to breaking down i hit wat appeared to be a pot hole and never stopped the car until i approached the junction in were i broke down
    a call out guy never checked this he said it might of been the hydrolics pushing oil into the cylinders but shorley there would be some sign off this as there are no leaks would there be leek off pipes under the car
    thx again dave
  1. Replies: 18
    Last Post: 20th November 2012, 21:41
  2. Replies: 53
    Last Post: 16th November 2012, 22:42
  3. white smoke on start up
    By m1ke823146 in forum Engine & Drivetrain
    Last Post: 5th April 2010, 23:31
  4. White/Blue smoke on start up
    By jsr645 in forum Engine & Drivetrain
    Last Post: 15th May 2009, 22:26
  5. White Smoke - Cold start
    By DG01 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 21:12
vectra c hard to start and white smoke
vectra c wont start smoke
