Results 1 to 10 of 13
Thread: mot faiure
    Regular Member VEC-MAN's Avatar
    Nov 2007
    LEICESTERSHIRE
    Default mot faiure
    took the car for mot today,failed on front wheel bearing,
    the wording was ROUGH WHEN ROTATED,
    i phoned vx and quoted £300.00 they have to replace the bearing complete with the hub, it comes complete.
    the garage where i had the mot £230.00 , not genuine parts, quinton hazel parts
    does this seem like a far price,
    Administrator plasma's Avatar
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    new bearing is about £150 from Vx
    and they are probably charging you about 2hrs @ £80 ph labour,
    from EuroCarParts bearing is about £120 i think,
    East Ayrshire
    Trim : SRI XP1
    It's not a particularly hard job to do, If you're handy with the tools i'd give it a bash yourself, there may even be a how to on here somewhere
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Is the wheel bearing an MOT failure?
    Regular Member damers2000's Avatar
    Aug 2010
    Pontefract
    Quote Originally Posted by justin32 View Post
    absolutely, the wheel will most likely have play in it
    Regular Member Pete B's Avatar
    Malvern
    No problem if you can do it yourself. Not a hard job, just find yourself a nice warm dry day unless you're undercover .
    While I still had my 06 Vec CDTi, mine became rough and noisy (but no detectable play) earlier this year and I did a DIY change. With these hubs, rough & noisy running comes long before 'old fashioned' hand detectable play. Cost of OEM hub assembly off e-bay less than £100, fitting took about 4 hrs & I did a 'How To', see here.
    Lots of heavy metal to move out of way but easy enough on a driveway.
    As I no longer have the Vec, I've now 'lost' the detailed paperwork for the hub purchase with its sale but I'll try and find the e-bay supplier and link to it.
    easy job to do ,takes about 130-140 mins top,,
    have a look here mate...wheel bearings
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    after market wheel bearings around £60 and i can change them in 40 minutes
    On the Forum
    405 Post(s)
    Engine : 150
    Mileage : 74000
    The ones for £60 will be non IDS ones, the IDS ones are more expensive
    Malvern
    This was the one I purchased. As yours is a later version (2006, same as mine) it'll be the same one you need.
    There are cheaper to be had but this is made by FAG, the same as fitted OEM.
