Thread: Removing Badges
    Sep 2011
    Northern Ireland
    Default Removing Badges
    Been reading various posts on removing rear badges and how it leaves a "ghost" of where the badge was, so decided against this now. Just wondering does the same same issue arise with removing the letters, ie "vectra", "2.0" and "sri".
    May 2011
    bispham, blackpool
    Quote Originally Posted by Baggers 2.0 View Post
    mine came off easy no marks i think its only a few that have the marks ghost etc but you will not now if your is one unless you take it off if it does leave a mark just stick it back on in the same postion and no one will now any difference you should do it i was like you didnt want the mark but in the end just went for it and havent looked back it looks so much better
    Regular Member dbgb25's Avatar
    Aug 2009
    Margate kent
    What I did is took the letters off and then heat the glue with heat gun , then quick spray with wd40 and just clean the glue. Quick and easy.
    Sep 2011
    Northern Ireland
    No problem. I'll get to it. Thanks
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    and the badges on the chrome strip come off very easy just use a good chrome cleaner to remove and shine
    Regular Member cossiejay's Avatar
    Mar 2011
    burnley
    Vehicle : vectra
    Trim : sri 150
    Engine : 1.9 cdti
    i have removed mine and my car is a 2002 model with 180000 miles and you can not see where they were guess it could depend on the colour
  1. opc line badges to replace sri badges
    By Jow20 in forum Styling
    Last Post: 22nd January 2012, 15:27
  2. Took badges off
    By willoftoon in forum Styling
    Last Post: 18th July 2009, 20:06
  3. New VX Badges
    By rik_t in forum Styling
    Last Post: 14th June 2008, 22:52
  4. removing badges
    By steve-wolves in forum General Chat
    Last Post: 31st May 2008, 20:06
  5. Removing Badges on Silver Trim
    By IrmscheRay in forum Styling
    Last Post: 19th October 2006, 21:43
