Thread: Cylinder Head Bolt Torque settings
    Sep 2011
    timbuktoo
    Default Cylinder Head Bolt Torque settings
    Hi,
    Can anyone please advise me of the correct Cylinder Head Bolt Torque (angle) for a 2003 Vectra 2.2 (Timing Chain engine) (X22SE??)
    Neil
    Engine : 1.9 CDTi
    Cant find a X22 engine.
    Is it petrol or diesel?
    If its petrol this should help:
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Z22se?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Sep 2011
    timbuktoo
    Quote Originally Posted by AntSSSS View Post
    Z22se?
    Yes, sorry Z22 SE
    May 2011
    lancs
    Hi Neil, torque below
    cylinder head 10 x main bolts use new bolts
    stage 1 - 20nm/15 lbt ft
    stage 2 - angle tighten a further 90 degrees
    stage 3 - angke tighten a further 60 degrees
    stage 4 - angle tighten a further 15 degrees
    head bolt tightening sequence below rhis might baffle your head a little lol
    7 3 2 6 10
    8 4 1 5 9
    cylinder head x4 timing chain end bolts 35nm/26 lbf ft
    Hope that helps mate
    Engine : 1.9 CDTi
    Quote Originally Posted by tommytonguedj View Post
    7 3 2 6 10
    8 4 1 5 9
    Is my picture not showing as thats nearly the same lol
    Where did you get the info from as mine starts at 30 nm and an extra after the last angle.
    May 2011
    lancs
    out of the haynes mate for the above engine i'll double check in the morning.
  1. torque settings
    By punkgsi in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2012, 09:13
  2. Torque Settings
    By lizard in forum Handling & Braking
    Last Post: 21st June 2011, 17:27
  3. Torque settings
    By Exclusive BV in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2011, 21:37
  4. Torque Settings
    By Jolly in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2008, 09:32
  5. Torque settings for head bolts
    By lesmon in forum Engine & Drivetrain
    Last Post: 1st December 2006, 21:17
vauxhall zafira head bolt torque settings
head bolt torque specs insignia
opel vectra cylinder head bolts torque
autodata head bolt settings vauxhall insignia
head bolt spec for 2002 holden vectra
z19dt head torque settings
vauxhall 2.0 cdti head bolts torch
vauxhall astra cdti head bolt torque settings
head bolts on vauxhall zafira gsi talk
vectra 2.2 head bolt torque
vectra 3.2 head bolt torque
z22se tightening torques
opel omega 2.2 talk settings
opel omega 2.2 2016 talk settings
zafira gsi head bolt talk
talk settings specs for opel omega 2.2 2003
vectra c head torque
head studs 1.9 cdti
zafira 1.9 dti engine torque settings
Holden Vectra head bolt torque specs
talk settings for head bolts vauxhall
head bolt tightening sequence 1.9 cdti
holden vectra 2.2 cylinder head bolt torque
opel record 2.2 cylinderhead torque swttings
1999 vectra b 2.2 ecotec head torque settings
