Thread: New discs and pads or just pads
    Regular Member dannycturbo's Avatar
    Aug 2011
    Letchworth, Herts
    Default New discs and pads or just pads
    I need to change my rear pads on my 2.0 turbo the vented discs have about a 1-2mm lip but look in good nick I was just going to take the lip off and just put new pads on or should I just change the lot.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    change the lot fella as the disc and pad set from vx is a tad over £50 but the cailper carrier bolts are a git to get off
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    as above fit new discs n pads, hardest part i found was winding the calipers back in
    Regular Member bigdave1701's Avatar
    York
    Caliper carriers need a breaker bar or an old ratchet with a length of pipe over the handle for leverage. (I found a section of trampoline leg worked a treat!!
    The pistons CAN be wound in with a big G clamp and a pair of mole grips but far easier (and less risky) just to buy a winding kit from eBay for £30 odd.
  1. New discs and pads
    By marktaylor in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 18:55
  2. Need new discs and pads
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2010, 21:46
  3. new discs and pads - '53 Sri T
    By edward in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2010, 18:04
  4. discs and pads!!!!
    By arkhan78 in forum Suspension, Wheels & Brakes
    Last Post: 3rd April 2009, 20:00
  5. Mintex Front Pads, Rear Pads and Rear Discs
    By The Gas Man in forum Parts for sale
    Last Post: 6th January 2008, 00:34
