Thread: Intermittent Central locking
    Sep 2011
    kent
    Default Intermittent Central locking
    Howdy peeps! only just getting to grips with the Vectra after only having it 2 days now! Annoyingly, the central locking has a mind of its own, sometimes it will work sometimes it doesn't, and sometimes when it locks/unlocks it doesn't do the drivers door an i end up having to use the key???
    Anyone else got/had this? any solutions?
    and also, I don't think the boot unlocks with the central locking as I always have to open it with the key. The button on either front door with a boot symbol, (guessing it pops the boot)? all it does is beep when pushed???
    Any light shed on these issues will be grrrrrrrrrreat
    Regular Member JohnSH8892's Avatar
    Jun 2011
    Cambridge
    Hey Alan,
    Do you have an estate?
    Sep 2011
    kent
    No, just the vectra hatchback..
    Regular Member hadiislam's Avatar
    Apr 2011
    Newcastle upon Tyne
    the beeping is normal on the boot buttons on the front doors... does the same on mine... doesn't pop the boot it just disengages the lock electronically so that you can open it just by pressing and lifting the boot lid with the button...
    Sep 2011
    kent
    Hmmmmm think ive got an electrical fault of some sort then...
    When i do the unlock button on the fob, 9 times out of 10 all it does is turn the dash lights and rear number plate lights on an doesn't actually unlock the doors? i have to put the key in the door to open them, an that too doesn't always open all the doors? and pushing the boot button on the door makes a boot but it doesnt unlock it, also have to use the key to open the boot??
    Regular Member CH-VECTRA-ELITE's Avatar
    Frimley
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 140000
    Sounds like the central locking in knackered, I had the same problem on my peugeot 206, although a completely different car i'm sure all the central locking work the same way. I needed new locks and rewiring to solve the problem. Get the codes read, it might come up with something. My wifes golf central locking is mad, with hers you press the button once for drivers door and 2nd for the other doors yet when you do this sometimes is will do one door, others 2, you have to press it a few times to unlock all the doors. When i had the codes read on her car is came up saying there was an electrical fault on 2 of the doors.
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    Its the electrical sender on the drivers door it controls the whole car had this problem with mine
    had it replace end of problem
    Sep 2011
    kent
    Right.... turns out the lock button on my fob was broken so done a temp fix???
    it now locks and unlocks every time but doesn't do the drivers door, sometimes it does but sometimes it doesn't? would that suggest the electrical sender that Crispy mentioned, also the boot wont unlock regardless!! have to use key every time without fail... same prob as drivers door or 2 separate issues?
    and to save making another thread, how can i test the alarm to see if its working??
    Sep 2011
    kent
    Raaaagghhhhhhh!
  1. central locking key fob
    By Mickyboy in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2012, 23:50
  2. Central locking
    Last Post: 13th October 2009, 19:16
  3. central locking
    By whitevanman in forum Vectra C / Signum Car Chat
    Last Post: 10th July 2009, 08:06
  4. central locking help !!!!!!!
    By VECKSZ in forum Electrical & ICE (including SatNav)
    Last Post: 14th April 2009, 17:37
  5. Central Locking
    By parapaul in forum General Chat
    Last Post: 18th October 2006, 20:48
vectra c central intermittent locking
vectra c key fob intermittent
vectra intermittent remote locking
2005 vectra c key fob fault
why does my number plate lights come on when I unlock or lock my doors on a Vauxhall Signum
vauxhall omega sometimes my drivers door dosent lock
