Thread: vibrating/shuddering/droaning noise???
    Sep 2011
    kent
    Default vibrating/shuddering/droaning noise???
    Hey hey peeps! just joined up today to see how you fine people roll got a 02 plate vectra 2.2ls yesterday (fixer upper/project)
    and have noticed, when you pull away, there is a vibrating/shudder felt mainly from drivers seat (as a passenger u cant really feel it) but as you progress through the gears it turns into a loud whiring/droaning noise!
    Am i right in thinking wheel bearing? jacked the drivers front up and spun the wheel an its VERY noisey, an you can feel vibrations on the wing just from spinning it by hand, but there doesn't seem to be any play in the wheel itself? can you get the noise without the play? or would that suggest its something else like CV joint or D/S etc??? I was thinking it could have been flywheel related but with the engine running on tickover, I rolled down a hill from standstill and it still done it? does that rule out flywheel?? sorry for the few questions
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    I would say drive shaft mate. With you feeling it in floor aswell.
    Although I would prob have a stab at changing bearing if it's already noisy
    Sep 2011
    kent
    KK thanks Am trying to get the wheel bearing kit on order but they keep asking me "with or without IDS" ...................... i know what it is an what it means but how do i know if I've got it lmfao
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    You won't have IDS on yours dude. It was only fitted as an optional extra to some of the later cars that specified it and all VXRs if I remember right.
    Sep 2011
    kent
    ok thats great! would something like this be alright?
    http://www.ebay.co.uk/itm/FRONT-WHEE...item45fca9ed67
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by Alansvecky View Post
    Should be. You will have a part number on the hub somewhere I would imagine, just make sure they match the ones on the Ebay link. I can't see it being wrong though, just worth checking with it not being a VX part and an Ebay add.
    Sep 2011
    kent
    ok will do! apart from that everything else seems fairly spot on slight oil leak but when done the mot check on it, there was an advisory back in 09 about a small oil leak an its still like it now?? so guna get that booked in to see where its leaking! defo not been a looked after car so will be cracking on with a few things to get it as close to perfect
    Sep 2011
    kent
    *UPDATE*
    Done the hub/wheel bearing today, my oh my was it hot
    anyways....the drive is so much smoother now i cant believe it! no horribly whining,vibrating noise but i still have a problem (only slight) with a bit of juddering but will make a thread in the other section as personally i think its something to do with the flywheel
  1. Rear Droaning Noise Update
    By Telboy in forum Vectra C / Signum Car Chat
    Last Post: 8th February 2012, 11:10
  2. Rear wheel droaning
    By Telboy in forum Suspension, Wheels & Brakes
    Last Post: 22nd December 2011, 14:15
  3. Front end humming vibrating noise!!!
    By Days of thunder in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2009, 07:03
  4. vibrating noise when turning left/right
    By valhalla in forum Suspension, Wheels & Brakes
    Last Post: 27th July 2008, 21:55
  5. Grating/Vibrating Noise
    By ANDREWS in forum Vectra C / Signum Troubleshooting
    Last Post: 27th March 2008, 11:37
vectra shuddering noise
vectra 08 shuddering noise
