Thread: gearbox problems 6 speed
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Default gearbox problems 6 speed
    just had the oil in my gear box changed about three weeks ago. using castroll gear oil and put in 2.4l. problem is since its been done when i park on a hill whith the front pointing up. when i get in the clutch sits higher than the brake pedal and when presses it stays pressed down. and i have to put my fut under the clutch and push it up otherwise its hard the drive. also they actual gear changes are smooth and the cars done 124k
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Have u checked the brake fluid level?
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Plus bleed through some fluid using a preasure bleeder. Rule out the fact that there may be air in the system before looking at anything more cinister.
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    why would the brake fluid make the clutch stay down on the the floor. the brakes are fine its just the clutch i have problems with.
    bedford
    The hydraulic clutch uses the same fluid reservoir as the brakes if there is a leak on the clutch system the level will be low, usually to the level of the fill pipe that comes out the side of the reservoir and runs down to the master cylinder for the clutch, if it's low then look for signs of brake fluid around the bottom of the gearbox bell housing
    Are you VXR Enough
    13 Post(s)
    Quote Originally Posted by zaf-vxr View Post
    That's why fella
    Administrator plasma's Avatar
    On the Forum
    360 Post(s)
    Engine : 150
    Mileage : 74000
    Theres the answer above, and also check to see if your clutch return spring hasnt broken as well, that'll stop it from coming back up
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    no the brake fluid levels spot on and the problems getting worse. could it be because i put 2.4l gear oil in?
    Regular Member LADmachining's Avatar
    Hampshire
    Quote Originally Posted by dan danz View Post
    The clutch problem is nothing to do with the amount if gearbox oil. You could drain it out completely and the clutch should still work normally.
    There is a problem with the clutch and/or operating system that has coincidentally gone wrong just after you had the gearbox oil replaced.
    Who did the work? Perhaps they opened the clutch bleed valve on the top of the gearbox thinking it was the oil filler point and let air into the system....?
  1. 6 speed gearbox
    By billyyoung in forum Engine & Drivetrain
    Last Post: 16th September 2013, 07:54
  2. 5-speed gearbox on 6-speed z22yh
    By Ant SRi in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 09:06
  3. 5 speed / 6 speed gearbox difference?
    By electron in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 21:27
  4. Gearbox Problems 6 Speed - Sorted.
    By The Doc in forum Engine & Drivetrain
    Last Post: 12th December 2005, 14:29
vectra 6 speed gearbox problems
