Thread: Electric drivers window not right
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    Default Electric drivers window not right
    Over the last couple of weeks when I start the car up the one toch option on the drivers window dosent work have to send it up and down fully to start it working. Passenger side works every time. But every time I stop and turn of car it's back to not work with one toch. Any ideas thanks.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Theres a how 2 I think to fix it. Something about holding the button down till it beeps. Ill try find it (otherwise search the how 2's)
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    hewre you go "If, like me, you lose one touch window open/close overnight, sit in car with ignition on, lower each window, close window then hold button for three sconds once closed. Hey presto, one touch open/close reinstated."
    Feb 2011
    Selby
    It shows you have to do this in the Owner's Handbook. After disconnecting the battery, you need to teach the windows where the fully closed position is again. Just wind them down fully, then wind them up by keeping your finger on the button - and then keep it there for another 3 seconds. Now the one-touch raise and lower will work again.
    If it's still forgetting it after you switch off, then you may have a wiring fault...
    Jan 2008
    Irthlingborough
    will go out and try thanks.
    Jan 2008
    Irthlingborough
    just tryed works until I turn of the power and still works after that but when I get out lock the car then come back and try again it has gone back to needing reseting by holing down the button. As well normally when you hold down the remote button to open the windows before you get in they still all go down but when you hold the button for them to go back up the drivers one stays down until you restart the car weired.
    Feb 2011
    Selby
    OK, so it sounds like it's a fault with the driver's side window only. At least that's a start. Whether it's a problem with the mechanism, motor, control electronics, relay or switch unit though - that's the issue!
  1. Drivers Electric Window Switch
    By a18nmk in forum Bodywork & Interior
    Last Post: 16th March 2017, 23:13
  2. Replacing drivers electric window regulator
    By Kev_A in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2013, 05:36
  3. Drivers electric window doesnt work?help
    By dazza2393 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2012, 23:14
  4. Drivers Side (OSF) Electric Window Mechanism with Motor
    Last Post: 27th August 2010, 08:59
  5. Drivers Electric Window Switch
    By Damian in forum Parts for sale
    Last Post: 6th June 2008, 17:05
