Thread: Can someone please....
    Regular Member wildchild's Avatar
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Engine : 1.9 cdti 16v 150
    Year : 06
    Mileage : 111250
    confused Can someone please....
    tell me what the lead n plug are for in the right hand compartment in the boot and the little amber light underneath autodim rear veiw mirror but it dosent come on all the while or is it to light up gear stick area
    the vec is a 06 1.9 cdti elite 150 if that makes any diff
    many thanks
    gaz
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The plug in the boot compartment if you have it is for the Tyre Pressure Monitoring System if you want to retro fit it. You may not have the complete loom, and it's odd that a facelift has that plug too.
    The amber light under the autodim mirror only comes on when it's dark outside. Put your lights on and put your hand over the windscreen part of where this sensor is, you will see the LED illuminate after a few seconds.
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Year : 06
    Mileage : 111250
    cheers buddy tell me more about this tyre monitor system please
    gaz
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    The sensors for the tyre pressure monitoring are fitted to the wheels when the tyres are off. A loom needs to be run on the underside of the car with the receivers on it, but don't ask me where, it then gets plugged upto the plug you found in the boot. Then you need to get it activated via tech 2. Then that's all if we are talking about the same plug.
    Sep 2011
    west-mids
    Vehicle : vectra c
    Trim : elite
    Year : 06
    Mileage : 111250
    just puzzling thats all thanx anyway but...... while we're on the subject of retro fitting i've ordered my hids today n when i get round to it i want to fit auto headlamp washers and self levelers but what would i need for the self levelling haedlights would it be just a sensor plugged in or somthing n would that need to be tech2'ed too thanx again
    gaz
