Results 1 to 10 of 15
Thread: Engine getting too hot?
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default Engine getting too hot?
    Ive noticed that my temp gauge is fairly active and never sits at 1 temp like all my other cars have.
    Its moved between 82 and 90 all the time and im worried that its going to overheat.
    Is this normal for vectra's?
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Can you please stop posting everything in Vectra c chat ! Use the correct section if it's regarding a problem.
    Irmscher Insignia CDTI 130
    Aug 2011
    Basingstoke
    Trim : SRI
    Sorry
    West
    As long as the fan kicks in & brings the temp down you're ok
    If your worried its going to over heat then just go out for a drive, get it nice and warm and then return home and let it idle on the drive to make sure the fans cut in and out.
    Although with both of mine the needle used to move to the 12 o'clock position and stay there, no matter what.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Just changed my thermostat & it goes 82-4 ish but haven't had it in traffic on a hot day yet.
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    mine used to sit at 12 and not really budge much, but if it doesnt go over 90 i wouldnt worry too much m8
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by the-wizard View Post
    Wrong info above its 86-88, on short runs at night & early am so would be slightly higher in hot weather so 90 isnt bad.
    Aug 2011
    Basingstoke
    Trim : SRI
    Cheers guys
    I dont know if this is or would have any effect on the engine temp but my coolant seems very watery,its not the bright pink that ive used in my other cars but a pale pink asthough its been watered down quite a bit.
    I had to suck some out as when the engine was cold(left over night) it was well over the max mark.
    I think im going to drain it out and refil it with some new collant mixed 50/50 with water.
    Nov 2009
    newcastle upon tyne
    No tht would not and never has effected the temp of the engine,all tht the colour tells you is how strong the mix of anti freeze.In all the time i had this car(3 years and 6 months) i NEVER EVER had any trouble with the engine temp,the water/antifreeze wouldnt of been overfilled while i had it.Maybes you should look at your driving style????
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
vectra b 2.2 dti sri building pressure
opel vectra engine getting too hot
vectra.2004 engine getting too hot
