Thread: Removing thermostat
    Herts
    Default Removing thermostat
    Is it straightforward to remove the thermostat on a 1.8 petrol? Slow warm up and poor heater suggest it's stuck open. Thanks.
    May 2006
    North Wales
    My 1.8 has a slow warm up but the heater is OK - gets warm in the car before showing on the dial. Runs at about 75-80oC on the dial after 3-5 miles. I asked at the dealers - its not an easy job - they wanted £100 to do it, but they said my thermostat was probably 'normal'.
    i'd try changing the sender first, much cheaper and easier to do... driveway job..
    Herts
    Many thanks guys. Checking the hose temperatures suggests the 'stat is closed when cold and does open, though perhaps sooner than ideal. Think I'll leave it be for now.
  1. new thermostat
    By wildchild in forum Vectra C / Signum Troubleshooting
    Last Post: 24th August 2012, 14:02
  2. can it be anything other than the thermostat
    Last Post: 20th January 2011, 22:36
  3. thermostat or thermostat kit?
    By IA76 in forum Engine & Drivetrain
    Last Post: 24th September 2010, 11:33
