Thread: Spanner lights again
    london
    Default Spanner lights again
    Just back from a 1500 mile trip in the v6cdti and went fine, then next morning started the car and was driving to work when it stalled.
    spanner light has come on and a quick diagnostics says the turbo pressure is wrong!! is this just a sensor or is something bigger and more expensive going on??
    the mechanic shook his head and said he didn't even know where to start on these engines, and last time i went to the dealer it cost £144 to get my bonnet open when the cable stretched so looking for a nice easy solution please
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    1st thing id try is cleaning the boost sensor fella
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Do you remember what the fault code was that was generated . for example what chris has suggested would probably generate a p0234 code
    london
    think it was a 0049 something to do with pressure from or to the turbo
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    check your intake and air hoses for splits
    london
    yep done that, just rang the mechanic again he says the car is faulting the boost pressure sensor but says this might not be broken but it is the obvious one for the car to say is wrong with the symptoms
    very confusing, think i will go back to a carb or even a horse and cart lol
    london
    ok can anyone tell me where the boost pressure sensor is on the z30dt????? everyone else seems to have the y30dt with lots of lovely diagrams of where it is, none for the z30dt
    help!!!
    Bristol
    When you take the cover off it is on the metal intake pipe on the right its on the top side off the pipe. You can't miss it.
    There is no 0049 listed for the z30dti.
    Jun 2011
    Elland
    Held on by one screw on the pipe above mentioned - although mine is plastic, not metal.
    Give it a clean, replace and...
    with the engine cover removed, get someone to hold the engine at 1500 rpm. It makes a bit of boost here, but not too much racket. Hear and feel for air leaks in the inlet system and intercooler. Look in particular at the plastic rigid pipe just off the throttle body (where the boost sensor is) mine split just by the TB. Also, another member has had a split in the flexi hose that this rigid piece is attached to. Give the rigid piece a wiggle and make sure it's tight on the TB, too.
    Once your sensor is clean and you're happy there are no leaks, if the fault reccurs, you need to find out exactly what code is being thrown and what the accompanying error message is, to make more sense of it, I reckon
    % the alternative is to obtain live readings from the sensors and make sure the readings they are giving are logical, not zero, less than barometric (i.e.gibberish and indicating a faulty sensor)
    london
    ah sanity reigns, thanks very much shall go pull everything apart and test it on the way to london
    have checked all around the pipe work for any splits etc but cant find any, and the garage did an injector check for me, again all fine. They also tried some valve, was in information overload at this point but again was working fine!!!
    Have also tried the brake and accelerator turn the key and got 2 fault codes of 0104 and 0500!!! Will search here to see if what they are
    Thanks again for the help
  1. Spanner Lights on??
    By felixx in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2010, 17:56
  2. EM & Spanner Lights
    By Gracey in forum Engine & Drivetrain
    Last Post: 30th April 2010, 13:42
  3. spanner lights on
    By timbarny in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2009, 14:33
  4. 03 vectra 2.2 dti auto spanner lights
    By newtovectra in forum Engine & Drivetrain
    Last Post: 29th April 2009, 22:54
  5. spanner lights come on again
    By david-bell in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2005, 21:08
