Thread: Weirdness
    Regular Member leeroyjenkins's Avatar
    Aug 2011
    Wakefield
    Default Weirdness
    Every so often (maybe once every 2 weeks) my CDTI Siggy has a lumpy idle with the Instant MPG showing it using 1.3 gallon per hour instead of the normal 0.2. No reason for this. I normally see it on a morning when I have just got to Work. Which is a quick blast down the motorway. Not sure what's up but if I leave it idling for long enough (like 30 mins or so) or turn it off and back on it seems to sort itself. There's no loss in power while I'm driving or smoke.
    I'm at a loss as to what's up with it
    Sodding Typical on Sea
    Sounds like the car is going into regen mode, try to let it complete the cycle as they don't like being interupted mid run,,
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by Derek Mc View Post
    As above.
    Aug 2011
    Wakefield
    Fairy Muff, Thanks for that I'll make sure next time that I leave it
    Jun 2011
    Elland
    Yes, as above - car doing a DPF( soot filter) regeneration. Let it complete, or either: the filter will clog and the car will go into limp, eventually conk out, or it will constantly try to do regens and use fuel like you've a hole drilled in the tank!
    Mine happens every 300 miles or so and lasts around 15-20 mins. Also runs like a dog and drinks fuel whilst doing it - it's normal, don't worry about it
