Results 1 to 2 of 2
Thread: Cv joint or wheel bearing???
    Regular Member jofenan's Avatar
    nottingham
    Default Cv joint or wheel bearing???
    Have had a knocking noise for a few days now. Worse when I go over bumps but is sometimes there when the road is perfectly flat.if I shake the steering from left to right it gets a lot worse!!! Just been under the car and checked bottom ball joints, wishbone rubbers and anti roll bar. I did the drop links about a month ago and they are still fine. Only thing I can find is the n/s outer cv joint has play in it. I can hold it and rattle it in the bearing housing.I can actually rotate it slightly so it knocks. I jacked the car up and did the wheel bearing check. There is no play at all. Could this be making all that noise???
    Regular Member amand's Avatar
    Feb 2011
    west London
    My rattling noise turned out to be arb bushes and a snapped spring
  1. HELP PLEASE which wheel bearing, with IDS or not ?
    By armoured farmer in forum Vectra C / Signum Troubleshooting
    Last Post: 13th October 2011, 17:27
  2. Wheel bearing ?
    By THE ROBO 1 in forum Vectra C / Signum Car Chat
    Last Post: 1st March 2011, 22:21
  3. Possible wheel bearing ?
    By neilb1 in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2011, 22:29
  4. Wheel Bearing
    By suj786 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 22:05
