Thread: Bio Diesel
    Nov 2010
    Maidstone
    Default Bio Diesel
    Does anyone know if you can use biodiesel in a 1.9 cdti?
    WGAF#5
    Quote Originally Posted by signum_rob View Post
    iirc Vauxhall dont recommend (along with many other manufacturers) the use of Bio Diesel in their engines ...
    only modern ones with the correct mapping and injectors are advised to run it
    lincolnshire
    a bloke i know who's an engineer reckons that bio diesel cleans all the injectors etc while in use , duuno wether he's right or not mind ???
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Don't put Bio Deisel in your CDTI, it may ruin it. Bio diesel can actually eat fuel seals and to my knowledge doesn't provide the best of lubrication for the pump and injectors.
    Regular Member DeeBe's Avatar
    Jun 2011
    South Shields
    Bio-Diesel will indeed eat fuel seals around the pump and lines, but only in a high concentration. Most places use a percentage of Bio-diesel in their regular diesel (around 7% iirc) but Gazza is correct, it is not great at lubricating fuel lines and pumps. It also settles in your tank too.
    Regular Member nozzleton's Avatar
    Mar 2015
    Doncaster
    Trim : SRI
    Mileage : 174000
    Looking at these posts I guess 100% biodiesel ain't good then as I did use it for about a month before n had a little blue smoke when I floored it n smelt like a chippy. Other than that all seemed ok
    Sent from my iPhone using Tapatalk
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. V POWER DIESEL Vs DIESEL
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2009, 21:22
  3. BP Ultimate Diesel vs Morrison's mucky Diesel
    By Big Knox in forum General Chat
    Last Post: 31st March 2009, 13:11
  4. Shell Diesel Extra Or BP Ultimax Diesel
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 13:25
  5. 2.0 Diesel
    By cp123 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2006, 23:50
