Thread: Gross Train Weight
    Regular Member tangoman's Avatar
    Berinsfield,Oxford
    Vehicle : VXR Estate
    Trim : VXR
    Engine : 2800
    Mileage : 3000
    Default Gross Train Weight
    Does anyone know where i can find what the GTW is for a GSi Hatch.
    Need info for towing a caravan.
    East Ayrshire
    Trim : SRI XP1
    User manual and also the plate which i think is on the piller at the drivers door
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    I think you'll actually be looking for the max towing weight. The gross train weight will be more relevant to your licence type. I.E. If you passed your test after june 1997 you'll only be allowed a max train weight of 3.5t. So 2000kg car + 1500kg caravan/ trailer would be your limit. Hope this helps
    East Ayrshire
    Trim : SRI XP1
    Quote Originally Posted by BigWilko View Post
    If you've passed after 1st JANUARY 1997, then you can only tow up to 750kg, you need B + E to tow over that
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by stevie16v View Post
    Sorry, Jan. My bad. Are caravan's not fitted with a brake though? I thought the weight of the towed trailer was increased if it was fitted with a brake but was not to exceed the unladen weight of the towing vehicle?
    East Ayrshire
    Trim : SRI XP1
    Nope, regardless of if it's braked or not its still 750kg max, you need the E cat to tow it. There's so many regulations, the only thing that changes for trailers over 750kg is that it must have a brakeaway cable connected to a operating braking system, under 750kg doesn't need that. I have a feeling that the max train weight will be 3350kg or thereabouts, so you won't be able to tow over 1300kg, Really need to check your plate tho
    Sep 2011
    Wellingborough
    I bought my 1.9 cdti to tow my caravan and all the tow weights were in the manual. If you have the relevant license to tow (ie old git like me), then you will find the maximum weight of a braked trailer that the car can cope with in the owners manual.In the case of a facelift 1.9 Sri that is 1600 kg.
    Just to complicate matters though you cannot tow anything in this country that is heavier than the kerb weight of your car which in my case is approx 1570kgs ( once again details in the owners manual).
    Hope this helps, if you are still unsure go to www.towsure.co.uk and on the front page you can find an outfit matcher. This allows you to add details of your car and caravan and see whether they would he a good match.
    Regular Member sla002's Avatar
    hayes, middlesex
    you can also check towing weights on the cars v5/logbook.
    Regular Member se4's Avatar
    Aug 2010
    wales
    WRONG!!
    http://www.direct.gov.uk/en/Motoring...es/DG_10013073
    As long as you're under 3.5 ton you can tow with cat B licence, and that trailer is lighter than car.
    I.e. 2 ton vectra pulling 1400kg caravan = LEGAL
  1. on a train
    By decks in forum Comedy & Humour
    Last Post: 17th April 2012, 17:35
  2. Steam Train
    By gaz1965 in forum Comedy & Humour
    Last Post: 14th February 2012, 12:26
  3. looking to train in lgv driving
    By Nickzx6r in forum General Chat
    Last Post: 16th October 2008, 17:16
  4. Bored! - sat on a train.
    By Duncan in forum The 'Off Topic' room
    Last Post: 19th June 2008, 21:39
  5. 1.8 vvt drive train???
    By jaff in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2008, 21:02
vectra c gross train weight
vectra gross weight
opel vectra gross vehicle weight
vauxhall zafira diesel grosd train weight
gross train weight
