Thread: Not my Vectra but a Corsa...
    East Midlands
    Default Not my Vectra but a Corsa...
    My mate has a problem with his Diesel Corsa,so i thought id give him a shout on you knowledgeable folk on here.
    Basically his car wont start or offer to fire,he has had his battery and alternator checked out which is coming back ok...?.Anyone.... no fault codes stored so he tells me.
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    broken wire between ignition barrel and starter / altenator maybe ?
    Jan 2010
    glasgow
    is there fuel getting to the engine? make sure or can you hear the pump prime if so is there air in the system if you cant hear the pump prime is the imobliser working ok also check the fuses and the relays as most new dervs fuel etc are ran off a relay
    East Midlands
    Update on his motor,h daddy you were on the right track,he s took it to a local indy and they are saying its the ecu fuse,?does this sound plauseable.
    Jan 2010
    glasgow
    how did your mate get on with the car ? and yes a fuse or a faulty/sticking relay would or may stop it starting
    Regular Member coldo's Avatar
    Scotland
    Is it a Corsa C?
    I had this issue on my old corsa c. Wouldn't turn over nothign... thing was dead completly...
    Turned out to be a broken earth. New earth cable fitted by the dealer from the engine somwhere to the body (I think... it was 4 years ago) and all was right again....
  1. from Corsa C to Vectra C
    By wright8672 in forum Introduce yourself.
    Last Post: 11th April 2010, 19:24
  2. new vectra!! got rid corsa
    By mitch in forum Quick Photo Album
    Last Post: 22nd January 2010, 17:58
  3. vectra and corsa
    By *enery* in forum Quick Photo Album
    Last Post: 24th January 2009, 22:05
  4. vectra sri to corsa vxr
    By tomfraser in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2007, 21:57
  5. corsa to vectra
    By birsob in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2007, 13:19
