Thread: Fuel Filter 2.0DTi
    Regular Member insignia28's Avatar
    Mar 2011
    Warrenpoint, NI
    Default Fuel Filter 2.0DTi
    Been trawling for a How2 or instructions on changing the fuel filter in my 2.0DTi. Any one know if there is a HOW2 or can tell me if its an easy job/ how to do it......
    Thanks in advance
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I'd do this with a hot engine because as soon as it kicks into life you'll be revving the engine to suck the diesel through without the engine dying. The filter is the round cannister at the back right of the engine bay. 2 pipes going into the top and an electrical connector.
    1) Unplug the electrical connector.
    2) Undo the screw on the lid, remove the lid and pull the old filter away.
    3) Replace the 2 seals - wipe them in diesel first.
    4) Put the new filter in.
    5) Fill the housing with fresh diesel or 2 stroke oil/diesel.
    6) Put the lid on and screw it down. Plug in the electrical connector.
    7) Crank the ignition in 15 second bursts until it fires. Don't do more than 4 at a time. If you have to, give it a few minutes for the starter to cool down. If it won't go, take the lid off the housing and make sure the diesel is still in there. Fill if needed.
    8) As soon as the ignition catches, foot down on the accelerator. the revs need to be high for it to pull the diesel through. Keep them raised for a while then let them drop. Then leave it to tick over for a while once you're happy it's running.
    If it still won't fire, you can crack one of the nuts off the fuel pipes before the injectors to bleed the air through.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by cont1204 View Post
    I'd suggest wiping them in engine oil instead. That's what my mechanic recommended to me
    Mar 2011
    Warrenpoint, NI
    Er ok, so what that says to me is have a mechanic pal near by just in case lol
    Regular Member VectraElite 2.2DTi's Avatar
    Sep 2010
    Longfield
    nah its so easy! just make sure you fill the housing back up with diesel when you put the new filter in
    Mar 2011
    Warrenpoint, NI
    its strange i have no problems with taking the interior to peices and refitting it, or adding electrical components to things, but when it come to mechanics, I doubt my abilities.
    TBH i was chuffed with myself for even attempting the Air filter and pollen filter. I know they are easy but its a start and led to wanting to learn to do bigger things to my car.
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. Replies: 3
    Last Post: 29th October 2008, 11:15
  3. fuel filter water draining 2.0DTi
    By holtie in forum Engine & Drivetrain
    Last Post: 25th April 2008, 13:43
