Thread: Weird problem
    gwent
    confused Weird problem
    Hi just done the headlight washers upgrade today had to wire the extra washer pump plug to the fuse box under the bonnet fuse f14 where a 10amp fuse was in place instead of a 30amp fuse so to the 10 amp fuse out but I had to get some 30amp fuse so a trip to auto factors and the engine management light came on and went in limp mode so pulled over and plugged my fault code reader in 4 codes came up tried to clear them but they would not so I put the 10amp fuse back in and it was ok. So why on the facelift 07 Sri 1.9 cdti 150 would this happen
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    On the facelift, or should I say Full Canbus, its position 13, not 14, for the headlight washers.
    gwent
    Well in the Haynes work shop manual F13 is central control unit ,ESP and F14 is headlight wash system
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 Vtec
    Mileage : 64500
    Can't help you then. I have preface and facelift VX manuals and the preface states #14 and facelift #13. The online facelift manual also states position #13. Page 251
    https://www.vauxhallproductforum.co....icles/2217.pdf
    gwent
    You was right the Haynes work shop manual is wrong i had a look in my car user manual and it said F13
  1. Weird Problem with PC..
    By macdad in forum General Chat
    Last Post: 28th March 2012, 23:36
  2. Hi and weird problem with me vectra....
    By gmundaY in forum Vectra C / Signum Troubleshooting
    Last Post: 11th September 2011, 00:57
  3. Weird ice warning problem
    By husky in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2010, 01:45
  4. weird indicator problem
    By geebee007 in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2010, 10:45
  5. weird possible ABS problem?
    By Xerath in forum Suspension, Wheels & Brakes
    Last Post: 11th February 2010, 15:46
