Thread: Any suggestions/assistance please!!!! Thanks.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Default Any suggestions/assistance please!!!! Thanks.
    Car is 2006 1.9CDTi Diesel Z19DT engine 120bps.
    Just had a brand new DMF and 3 piece clutch kit fitted by a mechanic. On starting the car, the flywheel noise is no longer there (at least I can't hear it) when the engine is running idle but once the clutch is depressed, there is a noise like scraping/rubbing or clanging together of metals coming from engine.
    When clutch is released everything seem to sound ok. Mechanic said there shouldn't have been any noise coming from the engine and has no idea what could be causing the noise. He insists the parts have been fitted correctly as he has/does this job on fleet cars for a taxi company.
    He will be back today to drop the gear box again to have a look but I need information/suggestions on the likely things that could be causing the noise when clutch is depressed so that we are not groping about blindly.
    If it's any help, the car was not going into 6th gear (engine off) after the job was finished but was sorted once the car was started.
    Mechanic also mentioned that there was "no drive" going through the gearbox or something like that.
    Any ideas please? thanks.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Clutch friction plate fitted wrong way round or release bearing
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by CritchvxD View Post
    Thanks. Will mention this to him when he gets here today.
    lincolnshire
    done a good few of these now and it should be silent ! he's done something wrong or not used the correct parts maybe ?? did he renew the slave cylinder ??
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Quote Originally Posted by bembo449 View Post
    I bought all parts myself. All parts confirmed by buypartsby and carparts365 with car registration, engine and gearbox number.
    Yes. A new concentric slave cylinder was fitted as well.
    lincolnshire
    summats defo wrong then buddy , hope he can sort it !??
    Regular Member coldo's Avatar
    Scotland
    Not great... I had this engine in an Astra and had to replace the DMF and Clutch.
    The noice you descibe was the noise i got when the DMF was on it's way out. Looks like somethign is not right or correctly alligned etc. You defo need to get him to have a look at it and sort it.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    Just as an up an update, this issue has now been sorted. Part supplier sent clutch plate with 24 splines rather than one with 20 splines. Claimed that was the clutch plate listed for the car by Vauxhall and was told I have an odd gearbox.
    Anyway, happy ending and thanks to all that replied.
  1. Need some assistance lads
    By Zero in forum Engine & Drivetrain
    Last Post: 9th April 2011, 15:41
  2. Redundancy assistance
    By Derek Mc in forum General Chat
    Last Post: 27th November 2010, 09:25
  3. AA breakdown assistance
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 20:27
  4. VX Assistance during 3yr warranty
    By 67688c in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2008, 19:22
  5. Vauxhall Assistance
    By iain.condliffe in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2008, 12:42
