Results 1 to 10 of 13
Thread: 8v 1.9CDTi engine cover bolts
    Regular Member travec19's Avatar
    Jul 2010
    Vehicle : Insignia
    Year : 2010
    Default 8v 1.9CDTi engine cover bolts
    Gents I have been given the run around by the local vauxhall dealer with reference to the two hex bolts and rubber grommets holding the front of the engine cover on my 1.9 cdti 8v Vectra.
    The guy on the counter was an idiot and tried telling me that they only get supplied with the cover, and then tried to sell me a new cover to the tune of £70, **** he also said try using elastic bands......mong.
    All Im after is the two rubber grommets, can any one help.
    Jan 2010
    Trim : 1.9 cdti
    Engine : 120
    Year : 06
    You should be able to get the rubber grommets from scrap yard or you can check ebay as well.
    wirral
    56 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Try a different dealer mate. As there probably only about 50p each
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Vectra elite
    Engine : 1800
    Mileage : 80000
    mates car the same and was told the same .. went renault as same engine and got 2 from them were only 15p each ended up giving them me as wasnt worth the effort of printing the invoice
    Jul 2010
    Vehicle : Insignia
    Year : 2010
    Have checked ebay and other parts suppliers but as yet no success, will try renault today, many thanks gents.
    Wales
    The rubber grommets get 'rattled to death' in no time - mine were shot at 10k. It doesn't seem worth replacing them.
    I'm sure that std electrical grommets could be squished into the hole. The hex bolts are just std M6/M8 bolts I imagine probably something like 20mm in length. - id replace them with those
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Think this might be the part number you are after buddy :- 90412865
    Not 100% certain though....... Made a note of the number before my Laptop went bang, but not got the parts catalogue on this (ancient) laptop to confirm.
    Fingers crossed its the right one
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    This should help you
    Year : 55
    Mileage : 92,000
    Just did a quick google search travec for that part number and found another post from here about the very same thing :-
    http://www.vectra-c.com/forum/showthread.php?t=113531
    Hope that helps
    Damo
    Already replaced:-
    Alternator,
    Regular Member Marky's Avatar
    Jun 2006
    North West
    Yep they are expensive for what they are. I replaced mine and the next time the car went into the garage the numpty mechanic knackered them again. grrr...
    The parts are numbered 7 & 11 on the epc diagram above:
    11096061 20 48 981 SCREW, M6 X 18, COVER TO CYLINDER HEAD about £0.30 + postage from here
    90412865 6 07 813 -BUSH, CYLINDER HEAD COVER CAP about £4.00 + postage from here
    The big rubber bush that fits into the back of the cover and into the ball studs are (number 9 on the epc):
    24453627 58 50 765 -STUD, 9.9 MM DIA., COVER TO CYLINDER HEAD
  1. Signum 1.9CDTi Ecotec Engine Cover?
    By carperjake in forum Styling
    Last Post: 23rd June 2012, 16:24
  2. Engine cover bolts 1.9 CDTi 8v
    By Marky in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2010, 13:47
  3. What are the bolts on the engine cover?
    By Marky in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd March 2010, 10:04
  4. 1.9CDTi 150 engine pics request - without cover
    By nick_s in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 18:13
vauxhall vectra engine cover
vauhall zafira engine cover bushes
zafira engine cover buffer
cam cover bolts size zafira 1.9cdti
90412865 6 07 813
Opel vivaro cylinder head 1.9 how many valve are there
vauxhall vivaro 1.9 cdti plastic engine cover securing bolts
vauxhall astra h engine cover bolts
vectra c 1.9 cdti engine cover rubbers
2008 Corsa cam cover bolts
06 vectra engine cover bolt
vauxhall engine cover bolts
bolts for engine cover z18xe
corsa c bolts for engine cover
vectra c engine cover screw
vectra c engine cover bolts
astra 1.7 cdti engine cover bolts
2008 vauxhall zafira 1.9cdti engine covers rubber buffer
vectra engine cover
vectra 8v intercooler diagram
