Thread: When should my turbo kick in?
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default When should my turbo kick in?
    Ive got a 2006 1.9cdti SRI with 65k on the clock and i was wondering when the turbo should kick in?
    It seems to be about 2.5k but ive read some people have it kick in at 1.5k?
    I cant hear it spooling up as i have a K&N panel filter fitted so just hear the engine.
    East Ayrshire
    Trim : SRI XP1
    mine is about the 1.5-1.7k mark
    Aug 2011
    Basingstoke
    Trim : SRI
    ok thanks mate...gonna check the boost sensor later as mine dont seem right.
    East Ayrshire
    Trim : SRI XP1
    Mine used to be about 2k until I cleaned the boost sensor. For 5 mines work it's well worth it, you may be surpised with the difference
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    clean the boost sensor and EGR valve - and also worth running some Wynn's EGR3 Inlet cleaner through too.
    Another thing to check - is your inlet swirl rod still attached?
    Aug 2011
    Basingstoke
    Trim : SRI
    Guys,
    i took out the boost sensor and it was a little oily but nothing too bad.I gave it a clean with some WD40 which got some of the rubbish off but not a lot.I didnt have time to do the EGR valve but will be doing both of them again 2mor with some carb cleaner...i thought i had some carb cleaner but i cant find it.
    I had a look at the swirl bar and its still attached but what i did notice that at the right hand side(look down from with knees on the bumper) is quite oily.Im not sure what the swirl bar sits ontop of but the other 3 rubber bits were fairly clean.
    Also i noticed that one of the rubber hoses(the 4mm 1 that people replace) is quite perished so will replace the short section when i get some.
    Thanks for you suggestions guys
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Mileage : 72K
    Mine starts pulling at 1700.
    Aug 2011
    Basingstoke
    Trim : SRI
    Mines all sorted now,cleaned the boost sensor and its perfect
  1. when does your tourbo kick in
    By c4rlos in forum Engine & Drivetrain
    Last Post: 21st June 2011, 08:57
  2. Kick Plates
    By Dwabo in forum Styling
    Last Post: 6th February 2008, 10:57
  3. Question B4 I Kick Off!!
    By TUX-VECTRA in forum Vectra C / Signum Car Chat
    Last Post: 18th July 2007, 22:06
  4. Kick Some Asphalt !!
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 29th November 2006, 18:15
