Results 1 to 2 of 2
Thread: brakelight switch
    middlesbrough
    Default brakelight switch
    hi my vectra 19cdti 8valve keeps blowing the brakelight fuse , wen the fuse blows it says brakelight chek on dashboard. however the brakelights do work wen fuse is blown as it switches to another circuit, ive vissually checked the wireing near ecu and fuse box etc but cant see any corroded wires etc can any1 help
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    That sounds like a tough one buddy
    I had a similar problem a few years back (Peugeot 206) and found that the metal circuit strips in the rear bulb holder had corroded and furred up, and was short circuiting/blowing the fuse.
    Might be worth looking at the rear bulb holder (as in pic below) and checking that there is no debris, blown bulbs or corrosion in there and make sure the wiring plugs are not loose.
    After that I wouldn't have a clue lol
    Best of luck and hope you get it sorted
    Damo
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
  1. Smoked 3rd brakelight
    By Matt_Bankier in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2011, 22:25
  2. Brakelight
    Last Post: 2nd December 2009, 18:42
  3. 3rd brakelight removal
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2009, 20:37
1.9 cdti vectra brake light switch blowing
