Results 1 to 10 of 20
Thread: 3.0 V6 weird running & idle
    Aug 2009
    Ascot
    Default 3.0 V6 weird running & idle
    Hi,
    Car has been running really well for last 6,000 miles since I did fuel filter change. . . . . But today the gremlins hit back.
    First I was driving down the M3 at about 70 when the re-gen kicked in so car was smoking a bit then everything seemed ok . . . Alas not to be, the car seemed to run under power, then every time I put my foot down as soon as it hit 3,000 rpm the car goes into limp mode ( but no lights ), the weirdest bit though is when stationery the idle is hunting, it goes between 800rpm and 1200 rpm!!!!
    Any ideas? My cheap code reader says no codes, and I have no lights but something is amiss, the idle bit is really confusing me
    Nick
    Regen on a 2005?
    Is it an estate?
    See earlier replies, take the car to a mechanic with experience of the Y30DT or Z30DT (depending on which is fitted as 2005 was the changeover year) for full engine diagnostic
    It is known that some engine faults are not extreme enough to cause fault codes, so needs traditional diagnostic (hammer and spanner)
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    change the fuel filter mate. I had it while i was on holiday this summer.Within a week the car was undrivable. For the sake of 10 quid i'd recommend giving it a go.
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Get some fuel system cleaner through it
    Aug 2009
    Ascot
    Would the fuel filter affect idle though
    Nick
    Aug 2009
    Ascot
    Regen on a 2005?
    Is it an estate?
    It's a 06 Z30dt, that will re-gen won't it.
    Nick
    Jun 2011
    Elland
    If it's going into limp mode, it will have thrown a code, but a cheap reader may only be able to read 'engine' codes and not spanner ones. Not all codes cause a light to come on, but any time mine has gone into limp mode, the spanner light has come on.
    You need a diagnostic able to investigate all codes... maybe even get some live data whilst the car is being driven, especially if the fault is readily reproducable
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by s2yob View Post
    Nick
    Well mine just seemed to be struggling to pull fuel through everywhere in the rev range. but mine was going into limp mode at 2000 revs at the worst point and was NOT throwing up a code.
    Aug 2009
    Ascot
    Quote Originally Posted by hebblemarine View Post
    And this morning . . . . . All ok!!!!!! Aaaarrrrgghhhhhhh
    Aug 2009
    Ascot
    Quote Originally Posted by BigWilko View Post
    Wilko,
    What was wrong with urs?
    Nick
  1. vectra gsi running rough misfires high idle
    By shaunft in forum Engine & Drivetrain
    Last Post: 9th August 2012, 23:03
  2. vec 1.9 150 running weird
    By n8sby in forum Engine & Drivetrain
    Last Post: 16th January 2012, 23:56
  3. z20net lumpy idle running rough
    By tomo41 in forum Engine & Drivetrain
    Last Post: 7th July 2011, 23:06
  4. 1.9 CDTI Lumpy Running at Idle
    By Dazfoz in forum Engine & Drivetrain
    Last Post: 13th April 2009, 18:23
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
https:www.vectra-c.comforumshowthread.php148150-3-0-V6-weird-running-amp-idlepage2
