Results 1 to 10 of 11
Thread: vectra z19dth
    Jul 2010
    Londonderry Northern Ireland
    Default vectra z19dth
    put a flywheel, clutch and egr valve on a vectra on saturday, on the way home from garage it made a huge bang coming up a hill and lost alot of power, i nursed it home and went out to start it there now and it is refusing to start, have no access to a code reader tonight, any ideas?
    East Ayrshire
    Trim : SRI XP1
    Is it turning over but just not starting? I don't want to put you down, but is it possible you haven't fitted something properly? I'd guess the dmf
    Jul 2010
    it was going ok for 5 mile or more then just let out a bang and lost power, its turning over ok, runs a few seconds then dies
    Jul 2010
    and car was driving well enough through the gears/clutching after it lost power, i'll get it plugged in tomorrow at lunch time anyway
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Possible flywheel collapsing would result in starting difficulties I'd imagine but as for loosing power, well that may be another issue.
    When you crank it do the belts turn?
    Jul 2010
    yep, belts turn, no dtc's in car fires for 2 seconds each ignition cycle
    Jul 2010
    disconnected the airflow meter and the car started and runs, plug it back in it cuts out, replaced airflow meter and its no better
    East Ayrshire
    Trim : SRI XP1
    must be something to do with the connection of where it runs to, eg ecu or sensor not happy with it
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    What happens if you disconnect the boost sensor? When a sensor is disconnected the engine will run on a limited map.
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    im just wondering if the wiring loom has either been trapped or strethed and damaged a wire, how did you support the engine whilst box was out?
  1. z19dth
    By neill in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 08:38
  2. Z19DTH - Which Oil?
    By treadstone in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 17:22
  3. z19dth
    By taralko in forum Vectra C / Signum Troubleshooting
    Last Post: 1st July 2006, 13:36
