Thread: Exhaust advice. What do go for?
    Regular Member mishima's Avatar
    UK
    Question Exhaust advice. What do go for?
    Hey guys - my exhaust is on the way out and needs replacing (backbox). The car model is LS so the exhaust points downward but I have the SRI rear bumper so there is an exit.
    Would I just need to buy an SRI exhaust for it to come out of the bumper? Would it fit fine?
    The other question is, beside the standard exhaust what other options are there for a single backbox? Any suggestions?
    Cheers,
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Yup remove the backbox there now and fit an SRi one. Can't remember if the pipes are a different size so unless someone else can clarify, get one from a 1.8. Failing that and if you want a little more noise, have an exhaust place remove the backbox and fit a pipe just going to some welded on tips. Should still be quite quiet if you're just pootling about, with some growl if you boot it.
    Regular Member Badger59's Avatar
    Sep 2010
    Telford
    Wink
    sri pipes fit no problem, i put the "y" section and some aftermarkets on my old one.You need the SRI bumper and twin exit from either 2.2 or 3.0.....
    this is all for twin exit
    if you dont want to buy a rear bumper and insert, buy the sri rear box and have the lower lip sprayed and cut, like this..
    UK
    Thanks mate. I have the SRI bumper just the old LS exhaust:
    So I can just fit either an SRI exhaust as a direct swap or a Sportex one??
    u will need to take a pic from underneath where the centre box joins onto rear box and i will let you know mate..However the floor plans are all but the same on all pre-facelifts, so cant see a problem..
    UK
    I have some pics for ya. Does it look like this might fail MOT?
    Hopefully I've taken the pic that you wanted below. If not let me know and I can take another!
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    thats the outer skin thats gone, but as said fit either sportex or similar or an sri box
    UK
    aye, will it fail MOT?
    Mar 2011
    llandrindod wells
    as long as its not blowing it should pass mate
  1. exhaust advice
    By daniel9807 in forum Vectra C / Signum Car Chat
    Last Post: 30th December 2011, 23:36
  2. exhaust advice..
    By lanky659 in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2010, 12:59
  3. exhaust advice
    By leonvectrac in forum Tuning
    Last Post: 10th May 2010, 11:05
  4. Exhaust advice.
    By Hyperhart in forum Engine & Drivetrain
    Last Post: 6th May 2010, 18:30
  5. Exhaust advice
    By lesbo in forum Vectra C / Signum Car Chat
    Last Post: 26th June 2008, 10:37
Vectra c sportex exhaust require bumper cut out
