Thread: Feathered tyres - advice
    Jul 2009
    Brighton
    Default Feathered tyres - advice
    Just had the MOT done last week. The vehicle report states the rear tyres are feathered. Girls behind the counter didn't know what this was and as it was lunch time so no-one else seemed to care either (great Vx service).
    My question is, what causes this?
    It's on the rear tyres, on the inside edge.
    Is this a tracking issue, or a suspension fault?
    The tyres are Nexen N3000 and have directional tread.
    I had a 4 wheel alignment done 2 years ago, so might get this done again.
    I'd look at rear bushes and dampers.
    Jul 2009
    Brighton
    I'd imagine if the dampers were shot, then I'd get flat spots on the tyres. This is more like the tread is raised on the inside edge. Outside edge OK.
    I assume the signums have some camber on the rears.
    Are the bushes easy to replace?
    Look at the rear "banana arms", rear control arms. A common failing point.
    Jul 2009
    Brighton
    Thanks for all that. I'll have to have a look later.
    Funny thing is, it passed the MOT, only required the OSF drop link!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Feathering is down to wheel alignment. So could be down to worn upper or lower arms
    Sep 2011
    Swindon
    Yep, had the upper arms advised on my MOT last week. The tester was knowledeable on the Vectras and said you can't feel the play in the upper arms when it's off the ground, you gotta give the top of the wheel a push and pull with the weight on it to feel it.
    Jul 2009
    Brighton
    Sounds like that's my problem.
    I'm half annoyed that the vx garage didn't spot this at the mot. Although if they did i'd have to pay their going rate and not have much time or choice. Cup half full and half empty.
    Jul 2009
    Brighton
  1. New tyres advice please!
    By cj_quest in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2010, 21:09
  2. Which tyres? - advice please
    By Paul82 in forum Vectra C / Signum Car Chat
    Last Post: 27th May 2009, 01:14
  3. Tyres Advice
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 2nd October 2007, 09:11
  4. Advice on Tyres
    By decho in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2007, 22:55
  5. feathered f*****s
    By bobbyboy in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2006, 07:36
