Results 1 to 10 of 28
Thread: 1.8 VVT Thermostat
    Doncaster
    Default 1.8 VVT Thermostat
    Mine is goosed, anyone changed one? It looks fairly straight forwards, is it?
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Yes its about the easiest one on the Vec range to change due to where it is situated, it is a bit more expensive though. 4 bolts, 1 hose and the temp sender connector IIRC.
    This is the one you need for your. Unfortunately the stat itself is not available on its own for the Z18XER, you need to buy the whole unit.
    http://www.ebay.co.uk/itm/Vauxhall-A...#ht_1324wt_698
    Doncaster
    Thanks for the reply. Just got the car though and the seller has said he'll fork out for it which is nice!!
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    sorry to jump in but not really. Mine looks to be on the way out. How would one go about fitting one of these?
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    What he said. Plus a couple of bottles of long life coolant for the change. 20, 30 min job. Done mine 3 weeks ago, Z18 XER also, 80 quid from stealers.
    Aug 2011
    Just outside Lincoln (so stuck in traffic!)
    Engine : 1.8 vvt
    Mileage : 67000
    Thread resurrection alert.Vauxhall want over £100 for a stat that includes the plastic housing. Can i confirm i can replace just the 'thermostat metal part' at a much more reasonable £70 from euro car parts as it looks like that part pops out??http://www.eurocarparts.com/ecp/c/Va...89e79c&000325I see the how2 is for the 18XE NOT the 18XER
    newport
    i got ours for £72 from vauxhall for the full housing, i dont think the vvti one you can buy just the stat on its own,
    as for changing it, it is very easy, just be careful not to overtighten the 4 bolts that fix the metal stat to the plastic type piece of the engine
    Aug 2011
    Engine : 1.8 vvt
    Mileage : 67000
    Sorry could u just explain further. You got the whole plastic unit from vauxhall and replaced the whole lot, it looks difficult as there is a metal pipe accross the front of it, or is that not connected?
    newport
    no the black plastic thing stays where it is, its only the metal housing that you have shown in the link that you change. there is 4 bolts that fix it in place.
    there is a how2 on here somewhere that i followed for doing the vvti thermostat, but im on my phone at the moment, so cant do a link
    Aug 2011
    Engine : 1.8 vvt
    Mileage : 67000
    i follow you now, you have just changed the metal thermostat regardless of what vauxhall have given u - Thanks ;-)
  1. thermostat
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2012, 18:08
  2. Can anyone tell me what a thermostat does?
    By twinxster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:03
  3. Thermostat?
    By killa_uk in forum Engine & Drivetrain
    Last Post: 31st January 2012, 18:35
  4. can it be anything other than the thermostat
    Last Post: 20th January 2011, 22:36
  5. thermostat or thermostat kit?
    By IA76 in forum Engine & Drivetrain
    Last Post: 24th September 2010, 11:33
vectra c 1.8 thermostat
vectra c thermostat replacement
vectra c 1.8 vvt thermostat
vectra c thermostat
thermostat vectra c 1.8
vectra c thermostat housing
1.8 vectra c thermostat
vectra 1.8 vvt thermostat
vectra c 1.8 thermostat location
replacing thermostat in vauxhall vectra c 1.8 sri
vectra 1.8 thermostat
vauxhall vvt thermostat
vectra c 1.8 thermostat change
vectra c 1.8 thermostat housing
vectra c 1.8 vvt thermostat 105 on itthermostat for vaxhaull vectra 1.8 petrolhow to change vectra thermostatvauxhall vectra c thermostat changevectra c 1.8 do i need to drain the coolant thermostat vectra c 1.8 vvt thermostat openingvauxhall vectra thermostat spring replacementvectra c 1800 z18xervectra c 1800 thermostatvectra 2006 1.8 sri coolant sensorsvectra c 1.8 xer temperature sensor location
