Thread: Interior light fault
    Full Member
    Nov 2009
    Warrington
    Default Interior light fault
    This may be a silly question so apologies if I is. I noticed the other night that my rear interior light above the rear passenger seat does not work. Front lights work fine when door is opened etc. I'm sure it's something very simple to fix but just checking it's not a common thing. 1.9 cdti Sri. Thanks
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Have u checked the bulb mate?
    Full Member
    Nov 2009
    Warrington
    Quote Originally Posted by paulvectrac View Post
    To be honest I haven't checked anything yet. Been too dark when I've been in to look. With it only being a 58 reg I didn't think the bulb would go that quick ( I should know to check the basics first being a heating engineer)
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Switches turned to the 'off' postion on the rear light? Or the lights forced off by the button on the front interior lights?
    Feb 2011
    Selby
    Might be worth checking the obvious - is the switch in the 'off' position? Is the bulb blown (just because it's only 3 years old doesn't mean the bulb can't have failed. What if the car had been driving on rough ground regularly? What if the rear light was on all the time because of children who don't like the dark?).
    It uses the same sensors as the front interior light, so the fault is most likely to be in the rear light unit itself, or the wiring to it which is a flat ribbon that runs on top of the roof lining.
  1. Interior Light Issue - Light & Button Illumination?
    By Leemarksmith in forum Electrical & ICE (including SatNav)
    Last Post: 7th November 2012, 23:36
  2. Interior light fault
    By pritch in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2010, 12:39
  3. interior vent fan fault
    By toofarfalls in forum Bodywork & Interior
    Last Post: 6th October 2008, 21:14
  4. interior light fault. help!!!
    By vecsxi in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2008, 00:11
  5. interior light fault
    Last Post: 12th February 2008, 20:22
