Thread: cant get eml light off
    Sep 2009
    birmingham
    Default cant get eml light off
    hi guys any help on this would be very much appreciated, ive got a vectra c 2003 sxi, z18xe, eml light has been coming on and off for some time, its been on constant now for around 3mths, had a new maf fitted 12mths ago, had new air filter, and new plugs all within the last 3mths, a week ago the car started to run really rough on tick over, sounds like it missing, and the exhaust has got a pop pop pop pop, noise coming from it, fitted a new front lambda sensor saturday, hasn't made any difference, took it to a good local garage, they spent two hours working on it, (not changing parts) just with computer, cleaned out throttle body, got rid of most ov the code, but two keep popping up, sorry forgot to write them dwn, mechanic told me the two codes that keep popping up, he has checked on the car and all is working as it should be, and cant understand why they keep popping up, has adviced me to go to a garage where they have a tech 2 machine, or go to the dreaded vauxhall dealer, as soon as someone mentions vauxhall dealer i see the pounds leaving my wallet!! ive since done a pedal test and got the following codes 0100, 0130, 0135, 0170 any help or advice, thanks guys craig
    newport
    stick your foot on brake and acc pedals, turn keys to position 2, your eml light should start to flash out a 4 digit code (1 flash for 1, 2 for 2, upto 10 for 0, then put the codes up on here to narrow it down
    edit: scrap that, only half your post loaded for me lol
    check 10amp fuse 15a under the bonnet fuse box
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    100 is the MAf, 130 and 135 are the O2 sensors, and the 170 is fuel trim
    Did you replace the MAF with an aftermarket one or a Bosch one.
    Sep 2009
    birmingham
    Default eml light
    it was an after market one, das definatly not a bosch one, had all fuses and relays checked saturday taffy while it was in the garage, mechanic also said the rear lambda, was flicking from active to inactive (on computer screen) while the car was ticking over, thanks guys
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    I quickly googled p0170 vauxhall and a few searches found that aftermarket ones still gave this fault, replacing with a bosch one solved it.
    Sep 2009
    birmingham
    Default eml light
    thnx for that info das, i will look into getting a bosch one
    Sep 2009
    birmingham
    can anybody else help me with this problem, thanx
    Sep 2009
    birmingham
    well pps got my vectra sorted, had to have a new ecu fitted, all runnin sweet now, thanks to the ppl that gave me advice
    Engine : 1.9 CDTi
    Doesnt sound cheap
    Sep 2009
    birmingham
    £288 lee all in, plus it had 2 go on a tech 2 aswell, considering i had quotes of over £550+ thought it was a pretty good price, just happy the car is back to normal
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
