Results 1 to 2 of 2
Thread: Anyone know this one
    Regular Member steve19cdti's Avatar
    Nov 2010
    s.wales.bridgend
    confused Anyone know this one
    Hi guys had spanner light on today after starting from cold ,bn having a lot off
    problems starting ,changed glow plugs,egr valve bn cleaned ,boost sencer cleaned,
    had problem with injectors thought it was number 3 injector cheacked them on op-com
    checked them in morning took them all ouit and founf out 1,2,4 injector was leaking diesal,number 3 was dry like thay should be so replaced the three injectors and still. The same.
    Had foult up again today checked it this code (p0380-08. Glow device general errar) would this be the relay next to. The battrey.
    Admin plasma's Avatar
    On the Forum
    333 Post(s)
    Engine : 150
    Mileage : 74000
    General error does point to a glowplug which you say you've changed.. Relay can be swapped out for another one to test it.. Best to try with someone elses if could save you the expense of buying another part in case thats not it
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
