my clutch pedal is staying in the fully depressed position and wont release by itself you can lift the pedal by hand so the spring is ok it has got to
be a hydraulic problem my flywheel knocks and bangs a bit but is it the release bearing or hydraulic unit ? when you turn engine off and pump the clutch pedal it seems ok but when you drive it goes back to the depressed position
