Thread: loud metallic rattling starting 2500-3000 rpm
    Jan 2010
    Tyne and Wear
    Default loud metallic rattling starting 2500-3000 rpm
    I have a 2.0 dti 52 vectra y20dth which has a loud rattling sound when revving it above 2500-3000rpm. It sounds like a very metallic rattling similar to the sound a loose heat plate would make but very loud and constant through all the gears above 2500rpm.
    I have had a look about and cant see any loose heat plates but it sounds as if it's coming from the engine anyway.
    I have noticed the belt/pulley that is visible from the drivers side wheel is quite slack, could this cause the rattle or is it more likely to be something else?
    Cheers,
    Drew
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try an feel for any loose pulleys. Although I would say loose pulley/ belt would be abvious regardless of engine speed.
    Is it defiantly a rattle noise. Could you maybe take a video may help someone give you advise?
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    turbo heat shield?
    Jan 2010
    Tyne and Wear
    I'll check the pulley's for any sort of play tomorrow thanks.
    It's not the heat shield I've replaced that and it's the same without it on, the other one was all bent and distorted for some reason so i just got one from the scrappy.
    I've uploaded a video but it's not really a very good example, I'll try getting a better one tomorrow.
    http://www.youtube.com/watch?v=JM5S5UTUqHc
    Thanks all
    Aug 2014
    Accrington
    Trim : 1.9 Cdti
    Engine : 1.9
    I know this is an old post but did you manage to sort this problem?
  1. Looking for metallic vinyl
    By cont1204 in forum Styling
    Last Post: 9th September 2011, 12:53
  2. £2500
    By BMAstra in forum Vectra C / Signum Car Chat
    Last Post: 6th November 2010, 00:44
  3. HELP! loud noise from stereo when starting car?
    By zipfree in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2009, 10:40
  4. Best polish for metallic black?
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2008, 10:52
  5. Metallic noise when turning
    By Dwabo in forum Suspension, Wheels & Brakes
    Last Post: 23rd July 2008, 19:56
vectra noise at 2500 rpm
1.9cdti very rattly on revs
