Thread: glow plugs relay switch
    Regular Member robengland9's Avatar
    Feb 2011
    london
    Default glow plugs relay switch
    does anyone know which relay switch is for glow plugs on a 1.9cdti?
    wirral
    26 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Relay is behind front bumper next to power steering pump
    Feb 2011
    london
    Quote Originally Posted by CritchvxD View Post
    cheers mate... been having problems with cold starting. Have new battery and engine turns over quickly, just changed glow plugs and cant see any fuel pipe leaks but still takes a few times to turn over..... not getting any alarm codes popping up and glow plug light desplay works ok, now running out of options so might just change the relay.
    Admin plasma's Avatar
    On the Forum
    184 Post(s)
    Engine : 150
    Mileage : 74000
    Glow Plug Relay is actually the biggish silver rectanglar thing you can see attached to the left handside of the battery box...
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    wirral
    26 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    O stand corrected then. On my v6 it's behind bumper
    Feb 2011
    london
    thanks for correction mines a 1.9cdti 120... most of the relays are with the fuses next to battery... someone now says its the big silver one so i will take their advice. Just searched threads about about cold starting problems and looks to be very common with the 120's
  1. glow plug relay
    By iwtand in forum Y & Z30DT Specific
    Last Post: 29th January 2012, 14:25
  2. glow plug problem or relay??
    By bobsimes in forum Troubleshooting
    Last Post: 23rd August 2011, 20:16
  3. glow plug relay and glow plugs
    By bobk1 in forum Engine & Drivetrain
    Last Post: 3rd September 2009, 17:02
vectra c 1.9 cdti glow plug relay location
where is the relay for signum steering pump
vectra c 1.9 cdti glow plug relay symptoms
