Thread: Injectors not shifting
    Regular Member Danger_MouseUK's Avatar
    Jan 2010
    Merseyside
    Default Injectors not shifting
    2 of my crush washers need replacing on my Z19dth.
    I've tried deblock oil and a slide hammer, but the injectors feel like they are practically welded in place.
    Anyone have any suggestions on how i get them out?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Their is a way. But you'll have to be super careful.
    Put injector pipes back on and crank engine. The pressure should make them pop.
    Should really be used as last resort.
    Try tapping side to side with soft faced hammer
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by CritchvxD View Post
    That sounds dangerous and I would advise 100% against this. Fuel jets from the injectors can be fatal.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    That's why a said last resort.
    The jet will be still pointing into the cylinder. and you'll only need to crank for 1/2 cranks.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    I ain't digging m8 but I wouldn't do it at all. Take it to a garage if you can get them.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Yeah I no mate was just saying my point. I understand it's dangerous.
    Most injectors usually break free after a bit of side to side with a hammer.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    The mech I use just left them as he said you need a special tool.
    Like I said though take it to a specialist or a mech who can get them sorted for you.
    Regular Member robengland9's Avatar
    Feb 2011
    london
    Quote Originally Posted by Danger_MouseUK View Post
    how do you know when your washers need replacing?
    Full Member
    Bristol
    If they are bolted down just lossen the bolts and crank over. That is what I have done in the past with no problems at all. Injection jets are dangerous only if you put you finger over the nozzel when they are injecting. If your daft enought to do that you should not be going near an engine. Sit at home and drive the tele thats the safest bet for some who would do that.
    Jan 2010
    Merseyside
    I really don't fancy cranking the engine, not with the pressures a common rail runs at.
  1. Auto Gearbox-poor shifting
    By millard2004 in forum Engine & Drivetrain
    Last Post: 22nd February 2012, 17:33
  2. Perfect Shifting/Acceleration calculator
    By Chuddy in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2011, 20:16
  3. Injectors
    By signumboy in forum Engine & Drivetrain
    Last Post: 28th September 2011, 21:23
  4. Shifting
    By treasure22 in forum Vectra C / Signum Car Chat
    Last Post: 17th May 2011, 15:41
