Thread: 1.9cdti(150) turbo
    Regular Member spidermonkey's Avatar
    Jun 2011
    mexborough
    Angry 1.9cdti(150) turbo
    on friday took the inter cooler pipe off the one that goes into the inlet manifold and there was quiet a bit of oil inside it so priced a new one up from a local garage and its is going to cost £850 fitted good jod i got extended warranty on my car go to phone the warranty company up on monday and try to get the work authorised.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Oil is naturally in that pipe, It gets sucked up from the oil separator directly into the inlet system prior to the turbo, If you have swarf or masses of oil along with sump levels dropping then it could be the turbo seals, I would vent to atmos for a while especially on long fast journeys to suck out all the oil that gathers in the intercooler then have another look, It does take a while to clean out as i do this periodically myself to do the same.
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    I doubt they will replace unless your swirl valves go as the manifold being choked with carbon is just how they have designed it to work..
    I second the wizard, I'm venting mine to atmos right after my MOT
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    If it helps, the venting system does not come into the mot so venting to atmos is fine all year round if you wish.
  1. changing the turbo on a 1.9cdti 120
    By john1 in forum Engine & Drivetrain
    Last Post: 1st January 2013, 22:55
  2. 1.9cdti turbo
    By olblue in forum Engine & Drivetrain
    Last Post: 15th March 2011, 00:40
  3. uprated Turbo for my 1.9CDTi 150
    By yatesy in forum Engine & Drivetrain
    Last Post: 20th February 2011, 23:56
  4. 1.9CDTi 150: Turbo Timers
    By barkzz in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2009, 22:41
  5. 1.9cdti Turbo Hose
    By bgm46 in forum Engine & Drivetrain
    Last Post: 17th June 2009, 22:33
